zenith Z50P3 PLASMA TV screen issues pink and purple grainy no image
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: zenith Z50P3 PLASMA TV screen issues pink and purple grainy no image
    and i kinda see in 4th and maybe 3rd
    pic where you say there may be a distinct horizontal area but its not there in the first 2 pics ....and its from the same tv...so ....
    • shelby5041
      • Feb 2009
      • 1505
      i do remember way back that there was a way to test for shorted buffers and i believe 1 or 2 were shorted in some combination between tvs .....does that help at all?? and thats why i bought 2 replacements from shop jimmy years ago..i have all my boards marked from shop jimmy and ones i got from ebay....
      • shelby5041
        • Feb 2009
        • 1505
        update....hope this info will help...did some tessts
        unplugged y buffers from y and display does not change at all on both tvs....also did temp test on all z and y heat sinks after tvs on for 20min
        z....heat sink 85deg f
        y..hsinks.....1....89deg......2....136deg
        basically same readings both tvs
        i then unplugged z power source and picture went totally black both tvs
        any ideas?
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by tw2005
          You have 2 sets of buffers, if it's only one board dragging the ysus down then you may get lucky and get half a good display isolating and swapping the buffer boards..........................................
          any ideas?
          or check the voltages on the ysus with the buffers removed and then with them connected
          • shelby5041
            • Feb 2009
            • 1505
            ok.....i think
            • shelby5041
              • Feb 2009
              • 1505
              #26
              ok.....when i get time i will try.....but i know im getting voltages to y because i get voltages from ps and heat sinks are getting hot......r u saying check voltages going to buffers?....when connected?
              • tw2005
                • Oct 2011
                • 6458
                Well to be honest, I'm not 100% on the LG/zenith but i was thinking check Vs, Va which comes from the PSU and on the Ysus Vsc(vscan) and -Vy which are generated on the Ysus and I'd try it without the buffers and then with for the ysus but someone out there probably has better knowledge if this is correct or a good idea.
                • shelby5041
                  • Feb 2009
                  • 1505
                  #28
                  well at this point im confident its bad y board and or bad buffers......i ordered a y for 25.00 shipped.....ill let u know......i think the 2...ys i bought 3yrs ago were defective...but its a guess...we will c
                  • tw2005
                    • Oct 2011
                    • 6458
                    Find out i guess, I was hoping you'd try just the upper buffer installed on it's own, then swap if no good then same for bottom but it's not like i know these thoroughly.
                    So if the next one does the same, what then? assume all 3 are bad or are all 3 good?
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #30
                      i did just have upper connected...no change both tvs
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        yes all 3could be bad or good....and a bad panel
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          this model tv if you google it is such a common issue...zenith was sued for it.......so im hoping its just a bad y
                          • tw2005
                            • Oct 2011
                            • 6458
                            fair enough and good luck, this time maybe
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #34
                              another update i get 0v when testing 5v pin going to y buffer...plugged in and unplugged
                              also what are the boards on bottom....z buffers?
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #35
                                i have never seen any reference to the horizontal boards mounted on bottom...not sure what their function is
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #36
                                  and when i test vs i get 180v per cheap harbor freight meter......panel says vs-193v
                                  is that ok?
                                  and when i check 5v pins going to z from y i get 0v
                                  maybe y board 5v circuit is bad?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Bottom boards are X buffers. These operate the vertical address..doubt it's your problem.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      is that ok?
                                      So you could isolate the power connector from the Y and measure the resistance on the 5v rail at the Y and see if it's shorted, could also confirm you see 5V from the PSU as you power up with out the y connected?
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #39
                                        i do believe i have 5v coming from ps but i will double check that when i get time....i did check some pins today and i do remember seeing 5v from ps
                                        but for sure no 5v from y to buffer and no 5v to z whcih on my tv comes from y
                                        all fuses on y are good...i checked the 2 large fuses and the small surface mount fuses 4 of them...all good
                                        one question though...is the 180v actual vs within tolerance of 193v vs spec
                                        thats over 5% difference is this ok or would create a noticeable problem?
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #40
                                          and thanks freak....i didnt think the bottom buffers were an issue qas my research found nothing about them....mostly bad z y and y buffers and mostly and from this list the y board is by far the most common issue on this tv
                                          • Vlad713
                                            LG 55NANO913NA Purple / Pink Line / Spot
                                            by Vlad713
                                            I am struggling with an issue on my LG TV, as mentioned in the title - please see the attached photos.
                                            The display / panel has been replaced in March 2023, under warranty - right before expiring after 2 years of use - due to a bunch of dead pixels.
                                            Then in a few months the purple / pink line started showing up, however the LG service said that this is not covered by any warranty, anymore, since the original one has expired.
                                            Recently I have just asked a repair firm to have a look and they have said that the panel needs to be replaced,...
                                            01-11-2024, 04:14 AM
                                            Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                                            09-07-2024, 12:40 AM
                                            Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                                            09-06-2024, 09:30 PM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
                                          • YellowJacket
                                            Asus VX238H - pink area over picture
                                            by YellowJacket
                                            Hi friends,
                                            I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
                                            I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...
                                            08-17-2023, 11:45 PM
