Help identifying part on samsung lcd main board
  • crosstalk
    • Feb 2014
    • 68
    • Usa
    I have been trying to figure out why my samsung ln40b630 won't power on. The power supply voltages seem to be ok (maybe a bit low on the 13v rail). Looking at the main board, I think I found a regulator (assuming it is a regulator) that has 0v output with 9v input. Can anyone identify this part? Is it a 1117 with 2.5v output? The markings if you can't see the photo are a sideways C with 11 on the first line, 17-25 on the second line, and 0917AG on the third line.
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Help identifying part on samsung lcd main board
    Maybe LM1117 -2V5
    • Neelix
      • Oct 2013
      • 145
      • South Africa
      • selldoor
        Slow Learner
        • 7870
        Yes it is a 2.5v LDO
        • Neelix
          • Oct 2013
          • 145
          • South Africa
          How were you able to tell that it's a 2.5V regulator?
          • selldoor
            Slow Learner
            • 7870
            I have come across similar ones before on these chips produced by
            (BacKwardC)ll both 17-33 and 17-25
            Three of us believe it to be 2.5v why would you think it would be something else?
            • Neelix
              • Oct 2013
              • 145
              • South Africa
              I don't recall having come across ICs like that before and was just curious as to how you guys were able to tell it's a 2.5V regulator, so that I could also learn
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                I personally know him and repeatedly met before
                • ERICSSON89
                  • Oct 2014
                  • 46
                  • NIGERIA
                  117-25 or 17-25? because I only know 117-25 is fixed regulator 2.5v output, but this 17-25 I'm little confused here
                  • selldoor
                    Slow Learner
                    • 7870
                    How can you be confused? - it is perfectly clear in his picture.
                    @ crosstalk - just replace it with any 1117 2.5v that has the same
                    dimensions
                    And here is a 17-33 3.3v from the same stable
                    https://www.badcaps.net/forum/attach...6&d=1391555176
                    • ERICSSON89
                      • Oct 2014
                      • 46
                      • NIGERIA
                      ok I see that now. 1117-25 & 17-25 are same right?
                      since he is getting the input voltage and no output I think he should replace with the same type
                      • crosstalk
                        • Feb 2014
                        • 68
                        • Usa
                        Thank you, everyone, for the help.
                          Did you also check the resistance on the output pin and ground to make sure you do not have shorted load or very low resistance?
                          • crosstalk
                            • Feb 2014
                            • 68
                            • Usa
                            Thanks, budm, for pointing out to check whether the output is shorted to ground. It does not appear to be shorted. It would be amazing if replacing the regulator fixes the board.
                            • electricboyo
                              • Mar 2013
                              • 26
                              I have personally seen a faulty LM1117 LDO chip. Not burned, no physical damage, but still it had no output. There wasn't a short circuit on the output. In my case, replacing the faulty LM1117 permanently fixed the problem.
                              The LM1117 is such a popular chip that many different companies make them. Perhaps they are not all equal in quality?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5022
                                • New Zealand
                                Very likely. And/or the design is running them too close to their maximum ratings.
                                -David VanHorn
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • Lee M.
                                  Samsung UN75RU8000FXZA bad main board?
                                  by Lee M.
                                  When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                  11-08-2023, 07:46 PM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
                                • JDC
                                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                  by JDC
                                  ONN 100012588
                                  Issue: No Power, Then Rebooting After Main Board Change
                                  Short answer: replace main board and power board
                                  Technical answer: replace main board and Q306 & Q307 on power board.
                                  Long answer:
                                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                  07-15-2022, 07:39 AM
