SHARP AQUOS 60" Won't Power On - LC-60LE810UN
  • kburks1230
    • Mar 2010
    • 87
    Trying to fix this big 60" LCD TV. It won't power on and just blinks blue on the front. No clicking or anything, doesn't turn on at all. Where do I start with this one? Any help is much appreciated.
  • kburks1230
    • Mar 2010
    • 87
    Re: SHARP AQUOS 60" Won't Power On - LC-60LE810UN
    Power board pic
    • kburks1230
      • Mar 2010
      • 87
      Board 2 pic
      • kburks1230
        • Mar 2010
        • 87
        Board 3 pic
          https://www.badcaps.net/forum/attach...4&d=1415407912
          OK, on the right side of the board, there white connectors with labels next to them, you will have to take the DC voltage readings on each pin when the TV is off and when the TV is on.
          Make sure to give us all the information:
          I.E.
          CN 11111:
          PIN 1, PS_ON, TV OFF= XXX V, TV ON = XX V
          PIN 2, ????, ??????, ????
          Just remember that we do not have the TV in front of us, so you have to give us all the details as if we have the boards in our hands to look at.
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            The service manual can be found here. You have to give the page a minute to load then a small get manual link will appear.
            It sounds as if you have standby voltage and the main board is attempting to turn on the set. It may be erroring out because of trouble with the backlight or power board. Sharp sets seem to predominately have backlight trouble. Do you have sound on any input? Or does the set not boot fully?
            Liberating magic smoke one part at a time
            • kburks1230
              • Mar 2010
              • 87
              There is no sound or anything. It doesn't seem to boot.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                If it just blinks steadily, it's possible that it simply always fails to detect a valid video input signal and thus stays in standby.
                Does it even look like it's blinking a code to you?
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • kburks1230
                  • Mar 2010
                  • 87
                  PD (bottom right of power board)
                  pins 1-10 are 0v
                  11 - 4.9v
                  12 - .12v
                  LB
                  All 9 pins 0v
                  L2 & L1
                  All 4 pins 0v
                  Those are the 4 white connections from bottom up on the right side of the power board. I can't get the tv to turn on to get ON voltages.
                  • kburks1230
                    • Mar 2010
                    • 87
                    I.E.
                    CN 11111:
                    pins 1-10 are 0v
                    11 - 4.9v
                    12 - .12v
                    LB
                    All 9 pins 0v
                    L2 & L1
                    All 4 pins 0v
                    • kburks1230
                      • Mar 2010
                      • 87
                      The logo LED blinks one time slowly then one time quickly.
                      • kburks1230
                        • Mar 2010
                        • 87
                        I have an update. I pushed the vol down, input and power, it took 5 seconds and the logo went solid, then after a few seconds the backlights flickered once briefly and the 1-1 blink started again.
                        • kburks1230
                          • Mar 2010
                          • 87
                          Any ideas? Should I try to take voltages in the time the TV is trying to power on after pressing the vol- input power buttons?
                          • kburks1230
                            • Mar 2010
                            • 87
                            Are the inverters on these PSU boards repairable? Which components typically go bad on the inverter? I've dead it's a common failure on these units.
                              It's usually the LED strip (inside the panel) rather than the driver (inverter) that fails.
                              • kburks1230
                                • Mar 2010
                                • 87
                                Is there a procedure to test for shorted or open LEDs without removing the panel?
                                  Only possible if you have access to a high-voltage current-limited power supply.
                                  • kburks1230
                                    • Mar 2010
                                    • 87
                                    Ok, Thanks Tom . Looks like I'll need to check the LED strips. I have the TV on the stand now with the back off. Do I have to completely remove the panel via the backed the TV or do I leave it assembled in the back and go in through the front by removing the trim? Anyone familiar with the steps of disassembly to access the LED strips I don't see it clearly in the service manual. The YouTube video I found starts out with the strips exposed already.
                                      The whole panel comes apart - this means the extremely delicate LCD panel has to be removed too. It is difficult enough to do it on a 40" set. I can't even imagine doing it on a 60" set. Good luck.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Definitely, you need room and a helper.
                                        Try not to touch the inside part of the panel, use gloves. Make sure, when you put it all together, that everything is super clean, because it will show. Even the diffuser sheets and everything has to be without dust particles, or finger marks.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
