Magnavox 47pfl7403d/f7 plasma stuck in retail demo mode
  • Paul Revere
    • Oct 2014
    • 11
    Does anyone know how to switch this back to consumer/home mode?
    Re: Magnavox 47pfl7403d/f7 plasma stuck in retail demo mode
    Should be an option in the first time setup menu, or if you do a factory reset.
    • Paul Revere
      • Oct 2014
      • 11
      It automatically comes on in retail mode and will not accept menu commands. This is one that's been lying around the shop for some time and I have no manual Not familiar with the factory reset procedure...
      • Paul Revere
        • Oct 2014
        • 11
        Just found the sticky on resets (I'm still learning what is on this site), will try that procedure..
        • Paul Revere
          • Oct 2014
          • 11
          That didn't work.. It won't accept any commands
          • Paul Revere
            • Oct 2014
            • 11
            bump
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Maybe via service menu?
              • Shinju
                • Mar 2014
                • 1239
                Do you have the original remote? Phillips/Magnavox do not like to play well with universal remotes, they have 4 color buttons on their remotes that DO NOT map to any universal remote (I have tried several high end remotes from All for One to my Harmony 520).
                Some of the options need these buttons to function as you have to set commands with them. If you don't have an original remote you might want to look into getting one and see if it works with one.
                • Paul Revere
                  • Oct 2014
                  • 11
                  I figured it out. Press and hold Volume +, Channel +, then press power with the buttons on the tv set. Whew.
                  • FlashFireSix
                    LG xboom PN5 stuck in demo mode(?). Looking for retail firmware.
                    by FlashFireSix
                    I took an ebay gamble on an LG xboom pn5 speaker which was listed as having battery issues (turning on then off).
                    I got it earlier today and concluded it's in a demo mode because of the following:
                    • When it's plugged in, it'll turn on and the power button will not turn it off
                    • Battery is healthy, reading 4.2v and not swollen, charges according to the xboom app
                    • the play/pause and volume buttons don't work
                    • You can pair to it and play music fine, as long as it's connected to power
                    • The bluetooth connection is disconnected after 5 seconds of audio pausing
                    • The DTS setting is defaulted
                    06-26-2024, 09:35 AM
                  • Omron
                    Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                    by Omron
                    Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                    My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                    - Tried to unplug radio and plug it back in into power,
                    - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                    - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                    05-23-2024, 01:27 PM
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • stormanimal83
                    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                    by stormanimal83
                    Hey....
                    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                    01-18-2024, 02:15 PM
                  • ekozeko333
                    by ekozeko333
                    🧠 What I’ve Done So Far
                    Flashed...
                    06-21-2025, 02:48 AM
