Philips/Magnavox lc370wx1 (sl) (04)
  • plbproductions
    • Oct 2014
    • 28
    Re: Philips/Magnavox lc370wx1 (sl) (04)
    Also could a diode be my problem
      Originally posted by plbproductions
      It's 6632L-0283A i did have backlight up until i changed that 2.2ul 450v cap i put the original back in but it still doesn't work
      If that is the case, then I would recheck the works real well.
      Can you show me where that cap is?
        These are the two inverters in your TV, right?
        http://www.shopjimmy.com/philips-996...verter-kit.htm
          OK, I need the DC Voltage readings on the MASTER Inverter board connector when TV is turned on.
          Pin 1 VIN = ???? VDC
          PIN 11 ADIM = ??? VDC
          PIN 12 ON/OFF = ??? VDC
          PIN 13 EXDIM = ???? VDC
          • Agent24
            I see dead caps
            • Oct 2007
            • 5082
            • New Zealand
            I just had another thought. If the original 2.2uF capacitor was 45v, but you used a 450v part, I wonder if the ESR is too high?
            And if the original one was faulty, that might be why it doesn't work when you put it back.
            -David VanHorn
            • plbproductions
              • Oct 2014
              • 28
              Pin 1 Vin 24v
              Pin 11 ADIM .883
              Pin 12 ON/OFF .883
              Pin 13 EXDIM .883v when board flashes 1.3v
              I know you didn't say to check it but I did
              slave board pin 1 24.0 constant
              • plbproductions
                • Oct 2014
                • 28
                Tom66 would you mind taking a look at this and let know what you think?
                  The Backlights (ON/OFF) is kind of low, I expect it to be more than 1V (you are getting 0.883V). Most panel uses around 2.5V minimum for BL_ON.
                  So what you can do is to remove the ON/OFF PIN from the inverter board, then use two 1.5V batteries connected in series to give 3V output, connect the negative to the chassis, the positive is connected to one end of resistor 330~1K Ohms resistor, another end will be connected to the ON/OFF pin of the inverter board AFTER the TV is switched on, the backlights should come on.
                  • plbproductions
                    • Oct 2014
                    • 28
                    will try it tomorrow
                    • plbproductions
                      • Oct 2014
                      • 28
                      couldn't find a resistor anywheres never one when you need it
                      • plbproductions
                        • Oct 2014
                        • 28
                        i removed pin 12 put 3.5 v with 3~1k resistor on pin 12 after board got power inverter would not flash blue again, until i removed the voltage then it flashed. the green light on the on/off switch was still green.
                        • fixit007
                          Samsung flicker - BN44-00932T board or else?
                          by fixit007
                          I picked up this TV that the prior owner said - just died.
                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                          05-04-2024, 06:14 PM
                        • alro7779
                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                          by alro7779
                          Hello, guys!
                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                          09-14-2025, 12:25 AM
                        • G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                          by G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                          It does power up when pressing the power button.
                          I already try the power button while plugin the plug with no result.
                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                          Could this be an PSU or eMMC issue ?
                          07-19-2025, 03:43 AM
                        • tonybig10
                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                          by tonybig10
                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                          03-07-2025, 01:03 PM
                        • howardc64
                          UN65TU7000 strobing / flicker
                          by howardc64
                          Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                          Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                          Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                          03-26-2023, 04:37 PM
