grundig vlc4120 c .. does not turn on ..
  • Hjolli.hardar
    • Oct 2014
    • 12
    • Iceland
    Grundig also known as beko and seems to have a lot of LG boards.
    here is the service manual https://www.scribd.com/doc/111572913...BS-8041S-8042S
    powersupply type fsp337-3f01
    ok i get only 5 volt's when nothing is connected to the power supply.
    when i connect i get
    5v
    12v
    24v
    dim 3.3v
    standby 1.1v
    bl 0.014v
    and starnsformer purring.
    when plugged in my blue light starts dim the brightens up like it's being turned on. but buttons don't do anything.
    no back light no sound.
    i found a diode on the primary part when i put my multi on it the purring lowers but the volt are jumping up and down.
    i'm thinking i need to fix the standby voltage but i'm a bit lost as to where the problem might be ..checked the caps the all seem to be ok. in board and off. diodes seem to be fine.
    well every thing i know seems to be fine besides the funky volts on stby and bl .. therefore me lost ..
  • Hjolli.hardar
    • Oct 2014
    • 12
    • Iceland
    Re: grundig vlc4120 c .. does not turn on ..
    well i kept on going through board and and ripped out all the regulators and transistors ..basicly all the 3 legged buggers .. tested them every one ok.
    i'm starting to think it's something on the bottom side of the board.
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Is the standby volgate ok when the power supply cable is unpluged from the main board?
      Keyboard not detected, press F1 to continue...
      • Hjolli.hardar
        • Oct 2014
        • 12
        • Iceland
        nope .. only get 5 volts to 5 voltplug.. and I've been watching the light better and it seem to be dim at plugin then brighten and dim again .. blue diode.
        but of course only when main board is connected .. only diff i see when pushing on of button is a jump in main(big) cap about 1 volt.
        It looks like dirty electricity it's not stable in the power supply .. out of the diode d105 i mentioned i'm seeing jumps from 1v to 180v and the main strans former purr changes.
        also when i put my metter on q102 and q101 .. mid leg ..
        i still havn't pulled out cooling grill with th201 and acompanying d201cq045 and d202-205 which are 3 legged can't realy read on the because of caps in the way .. but seems to be stp30h100ct
        • Agent24
          I see dead caps
          • Oct 2007
          • 5069
          • New Zealand
          Please post photos of the board, show components you are testing, hard to follow without seeing.
          If you can download that manual and upload it here or elsewhere, that would help, I can't view it all online as I don't have an account on that site.
          -David VanHorn
            "ok i get only 5 volt's when nothing is connected to the power supply.
            5v
            12v
            24v
            dim 3.3v
            standby 1.1v
            bl 0.014v
            and starnsformer purring."
            If the standby power supply is not working you will not be getting the 12V or 25V which is turned on by the main board which runs on the standby 5V.
            The inverter board is not getting the BL_ON signal from the main board, it is getting only 0.014V.
            BTW, what do you use for the Ground ref for the meter when you are checking the voltages in the primary side of the circuit. What DC voltage do you get at the two legs of the main filter cap in the primary side when the TV is off and when the TV power switch is activated?
            • Hjolli.hardar
              • Oct 2014
              • 12
              • Iceland
              volts on main cap 394v use metal frame as ground ..
              i just replaced grill with q601-2 and d 602 -fb601..
              backlight comes on now ..
              get bl Q 1.777v others are the same .
              purring stopped .. but i get nothing on the screen ..
                OK, when you make any DC voltage measurement in the primary side of the circuit, you will use the negative leg of the main filter cap in the primary side as the ground ref for your meter, you cannot use the metal frame, that is why the voltage readings do not look right. When you work on the secondary (cold side), you can use the metal chassis as the ground ref for the meter.
                You are not getting the backlights because you do not have BL_ON signal.
                • Hjolli.hardar
                  • Oct 2014
                  • 12
                  • Iceland
                  got backlight on now 1.770v .. purring almost disapeared .. but i get no pic.
                  the measures i was posting come from the cold side.
                  i just hit the hot side diode by accident and noticed the purr change.
                  but it seems the problem lies in these q's i just put back in .. nothing else has been done though the window is open and it's blowing a bit cold straight down on the tv ..
                  gonna try connecting some sound to a source and see what happens
                    OK, so the backlights are on but no pictures, then verify that the LVDS cable between the main board and the T-CON board is properly connected, if it is, then the next thing will be checking the DC Voltage at both ends of the SMD fuse on the T-CON board.
                    • Hjolli.hardar
                      • Oct 2014
                      • 12
                      • Iceland
                      T-con fuse gives me 0v, 0.2 ohm .. so i gues no power is heading there ..
                      the main board is VEV190R-4 v-0.. seems to be LG manufactured though it comes up in searches as Beko, Grundig or Lg like all the boards on this one ..
                      • Hjolli.hardar
                        • Oct 2014
                        • 12
                        • Iceland
                        time to put kids to bed ... getting around 1mv on the fuse .. will take a closer look at the main board and t-con to morrow
                          OK, it means that the main board is not supplying the Voltage to the T-CON, it is usually done through a switched MOSFET on the main board that is turned on when the power switch is activated.
                          • ERICSSON89
                            • Oct 2014
                            • 46
                            • NIGERIA
                            please can u upload pictures of the psu board, main board and TCON board? both front and back please
                            • Hjolli.hardar
                              • Oct 2014
                              • 12
                              • Iceland
                              will do ..
                              • Hjolli.hardar
                                • Oct 2014
                                • 12
                                • Iceland
                                pics
                                • Hjolli.hardar
                                  • Oct 2014
                                  • 12
                                  • Iceland
                                  when i woke up i was going to continue but now there is no purring .. no dim, 12v or 24v
                                  all i get now is 5v, 1.5v on bL and stby 1.1v
                                  and nothing was done since last nite .. BL worked and now it don't .
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5069
                                    • New Zealand
                                    Have you inspected all the solder joints? Maybe intermittent connection somewhere.
                                    -David VanHorn
                                    • Hjolli.hardar
                                      • Oct 2014
                                      • 12
                                      • Iceland
                                      gonna rip it a part tomorrow and see what i find
                                      • vouager
                                        • Sep 2014
                                        • 3
                                        • pakistan
                                        You have Brocken Firmware!!!!
                                        Ask here for Help:
                                        http://forum.iwenzo.de/reparatur-von...amer--f26.html
                                        Sorry for my bad English
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • madsox
                                          Harman Kardon AVR 171S - standby led lights up, does not turn on
                                          by madsox
                                          Greetings!
                                          Thank you in advance for your understanding, I am writing to you through a translator.
                                          A Harman Kardon AVR171S amplifier was given.
                                          The history of the machine is as follows:
                                          It was faulty when I bought it, I want to fix it.
                                          I replaced the HDMI switch and one of the DAC ICs in it.
                                          After that it worked without a problem.
                                          I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                          The cooling was faulty, I will fix this later.
                                          I switched it to standby mode, waited for...
                                          09-24-2022, 10:46 AM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • Adenitz
                                          Troubleshooting Vestel TV, has standby, but cannot turn ON
                                          by Adenitz
                                          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                          Both boards are shown in the attached photos.
                                          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                          12-27-2023, 03:43 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
