Vizio SV420M, Power light stuck on. No standby or picture
  • SmartSped
    • Oct 2014
    • 51
    • US
    Re: Vizio SV420M, Power light stuck on. No standby or picture
    I retested the voltage with the cable attached. I'm getting the 12V now. Sorry for the confusion. So power board seems ok?
    Do you think there's a remote chance of getting this working by replacing the EEPROM? I do know how to solder and have the necessary tools for it. Of course I wouldn't hold it against you if it didn't fix the issue.
      OK, good. EEPROM, may be or may be not but since SJ sells EEPROM chips, then it is more likely to have EEPROM problem. You can E-MAIL SJ and ask questions, they are pretty good on giving info.
      • SmartSped
        • Oct 2014
        • 51
        • US
        Ok. Provided I get the OK from my friend (whom the TV belongs to), I will go that route and I'll report back here with my findings.
        Thank you guys so much.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          If there is a power up relay I would verify that it is being told to stay on otherwise the contacts have fused shut and that will cause all sorts of problems with the protection circuit in these devices. It has over voltage and over current protection and depends on a soft start up to work properly.
          • Amraks
            • Nov 2011
            • 725
            check screen with flash light just to see if anything is being displayed on screen.
            If you get Scan displayed on screen, it would be epprom.
            • SmartSped
              • Oct 2014
              • 51
              • US
              #26
              The relay thing sounds like it is a little bit above my understanding of electronics.
              As far as the flashlight thing, I tried seeing if I could see a picture with one a couple days ago but I didn't see anything. I'll look again more thoroughly tonight and make sure.
                There is no relay on this power supply-inverter board combo.
                http://www.shopjimmy.com/media/catal...2-0780-top.jpg
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  I am talking about a power on AC relay. What I have noticed on some devices they have a feedback circuit that keeps the relay on or it turns off when either the power button is pushed or there is a problem with the current of voltage on any of the boards. If this TV does has a relay like that, then if the contacts fuse together the start up of the power supply would be to quick and there would be to much of a surge of current. The software would detect this and depending on who wrote the software it can turn of the whole thing of part of the circuit.
                    No AC power relay used in this TV so the OP does not have to look for them.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      OK just did not know, I know they are used on some models. Have only done some CRT repair and a couple of LCD, but do understand software has a lot of control, maybe to much control on these newer TVs.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Still the power on button should work to shut the unit down. If it is not doing that than there is something wrong at that point.
                        • SmartSped
                          • Oct 2014
                          • 51
                          • US
                          #32
                          Hey guys. Just wanted to follow up on this. I replaced the U14 EEPROM but I still have the same issue.
                          Any other ideas on the possible cause or should I give up and try to find a main board?
                          • SmartSped
                            • Oct 2014
                            • 51
                            • US
                            #33
                            Bump. Anyone?
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              I am not an expert on these things, but do you have aside panel or button panel that controls the input, menu etc? If so I would try and dis connect it from the main board and then plug the TV in and see if it still powers up by itself.
                              • SmartSped
                                • Oct 2014
                                • 51
                                • US
                                #35
                                Maybe a stuck button or something? I'll see if maybe I can disconnect the buttons and see if maybe that changes something.
                                • x_orange90_x
                                  Vizio E550i-A0 no power, no standby light
                                  by x_orange90_x
                                  I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                  11-20-2023, 09:49 AM
                                • p-top
                                  Vizio, E60u-D3, no standby light, no ps_on
                                  by p-top
                                  Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                  main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                  PS voltages
                                  1 VSNS -2mV
                                  2-5 LED-OUT -2mV
                                  6-10 GND -2mV
                                  11 +16VS 16.29V
                                  12 AC-DET 3.929V
                                  13PS-ON -3mV
                                  14 +16VS 16.29V
                                  15 +16VS 16.29V...
                                  11-27-2023, 10:44 AM
                                • ChristianBr01
                                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                  by ChristianBr01
                                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                  04-23-2025, 01:48 AM
                                • bunting78
                                  Vizio D650i-B2 wont trun on and no standby light
                                  by bunting78
                                  First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                                  09-23-2021, 08:53 AM
                                • fharris1977
                                  Vizio D50u-D1 Dead Set No Standby
                                  by fharris1977
                                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                  12-28-2023, 10:25 AM
