Insignia NS-LCD37 flashes please wait then turns off
  • hbob17
    • Nov 2010
    • 20
    This is my first post so I hope that I have posted it in the correct section. I posted on one of the other threads pertaining to a similar problem but the thread seemed dead. I have followed all of the fallowing threads but have come up empty handed.
    https://www.badcaps.net/forum/showth...light=ns-lcd37
    https://www.badcaps.net/forum/showthread.php?t=21865
    I have the ns-lcd37 and the TV will power up flash please wait for a second and power off. I have tried forcing the TV to an input on start up checking the screen with a flash light, and it has no video or sound after the please wait screen flashes. I have tested all the outputs coming off of the power supply board and all appear to be the correct voltages. In addition I have checked the transformers on the inverter board and all seem to be at 2.2k ohms. I have also tested all of the fuses on the inverter board and all have continuity. Any help will be greatly appreciated.
    Attached are pictures of all boards with model numbers as well
  • hbob17
    • Nov 2010
    • 20
    Re: Insignia NS-LCD37 flashes please wait then turns off
    Installed new main board (6HA0136910 - 37HA37) and the TV will respond to the Power button, when plugged in the TV remains off until power button is pressed and will stay on until the power button is pressed again to turn off. But now it seems when i power up the TV, the green light will come on but the TV has no sound or video now and doesn't even flash the please wait screen any more. I am assuming now that it had to have been a cascade failure because now i am getting a proper PON voltage, but am at a loss for what could be wrong now. Any suggestions for what i should be checking next?
    • hbob17
      • Nov 2010
      • 20
      • triplefour
        • May 2014
        • 1747
        i just picked up this same tv the other day, it was missing the PSU and the IR/LED board
        i found a psu for 17 bux so i took a chance and bought it.
        now i have the same problem you were having with the flashing please wait... and then going blank.
        its a little different though. because my tv does respond to the power button, and it doesnt turn off after please wait, it stays on until i press power again.
        but at no time during any of this do i get sound or video, or can i change inputs.
        i have also checked with a flashlight and running my n64...
        i also have all the expected voltages on the PSU board, but i havent checked the inverter yet
        here's the service manual...havent read it yet but it may be of...uhh..service
        Don't fear the repair...
        • triplefour
          • May 2014
          • 1747
          hmm..the top most inverter's pins seem to read 2.09k on mine while all the others read 2.19, 2.18, 2.15 at the lowest...
          is the 2.09k cause for replacement?
          would this board work? it looks the same but has a slightly different number
          http://www.ebay.com/itm/SAMSUNG-LN37...item1c403f576e
          i ask cause its the cheapest one i can find, and theres 2 of them!
          whats really puzzling me is how i appear to have a main board that works (will on and off properly) but i cant get sound or picture! usually i am able to see something with a strong light, and press input until i hear sound...
          does anyone know if this tv is simple with pressing the input to change the source? i have run into tvs where changing the input was not as simple as just pressing the button. you had to select the input and press another button to ok it. big pain in the ass, but i guess it keeps u from accidentally changing the source when it is working...ruins your day when youre trying to troubleshoot though!
          • hbob17
            • Nov 2010
            • 20
            I was testing the TV and found that the smallest connector coming from the power supply to the main board looks like the signal to tell the power supply to turn on the inverter board.( its the 3 wire connector ) i unplugged this and then plugged in the TV and the inverter/back light seems to kick on so that led me to believe that the inverter board was fine
            • hbob17
              • Nov 2010
              • 20
              i think as long as the transformers are all above 2K that they should be fine, as long as they are not like a high reading like 47k or not bottomed out like 0K
              • hbob17
                • Nov 2010
                • 20
                If your inverter board is like my board you would want to look for http://www.ebay.com/itm/CPT-CLAA-370...item3f2dea18d9 (4H.V1838.401/D)
                • triplefour
                  • May 2014
                  • 1747
                  i tested the 2 fuses on the inverter board and they are .3 ohms, so fine...but when the tv is on, i only get 23.5v on either side of the fuses...shouldnt it be 24? is this why its turning off?
                  oh and when you say you unplugged that wire and then turned on the tv, the backlight stays on now?
                  pretty sure i did this same thing before, and it makes it so that as soon as i press the power button the backlight flashes for an instant. but i do not see "please wait" on the screen.
                  normally it takes a good 5 seconds before the backlight kicks on for a moment and i see "please wait"
                  not sure if seeing the backlight flash for an instant like that with one of the connectors unplugged "proves" anything..but maybe u know something i dont?
                  • hbob17
                    • Nov 2010
                    • 20
                    There are 3 fuses on the inverter board, 2 large ones on either end of the board and one very small one in the middle of the board that has a D on top of it
                      23.5V vs 24V not going to cause a fault
                      • hbob17
                        • Nov 2010
                        • 20
                        im still at a loss as well, my TV with the old main board used to power on a flash please wait and turn off. now with my new main board it will respond to the power button to turn on and turn off but now i am not getting any video or sound just a green indicator light that the set is turning on and off
                        • triplefour
                          • May 2014
                          • 1747
                          were you getting video and sound after the "please wait" on the original main board? did u just press input until u heard sound? but u couldnt turn it on or off, it just came on by itself and you could only turn it off by unplugging?
                          how would input work but not power on/off?
                          • hbob17
                            • Nov 2010
                            • 20
                            all my transformers on the inverter board are reading 2.1k and (f1 = .7)(f2 = .4)(f3 = .4)
                            • hbob17
                              • Nov 2010
                              • 20
                              no it would come up flash please wait and then instantly turn off almost like its power cycling.
                              • hbob17
                                • Nov 2010
                                • 20
                                would turn on by it self and would only turn off when i unplugged it
                                • triplefour
                                  • May 2014
                                  • 1747
                                  i think in all the tv's ive worked on, if it was just the inverter was out, or unplugged, the tv would still function just fine...just with no backlight (really dark but u can see video with a flashlight). is this one different? does it freak out and crash if theres no inverter? if someone had a working one, i would ask them to unplug the inverter and see what happens. see if they get the "please wait" flash or not...see if they get video and sound... if they did, then i would suspect mainboard problem here...but if they get the "please wait" and crash then i would suspect my mainboard is doing what it's supposed to, and theres a problem in my inverter somewheres...
                                  • hbob17
                                    • Nov 2010
                                    • 20
                                    well i was looking on this thread https://www.badcaps.net/forum/showth...light=ns-lcd37
                                    and it appears to be the 32 inch version of the same TV, same boards and such, and they had said that it was the power supply fuses i think
                                    • updateemu
                                      • Mar 2014
                                      • 10
                                      • usa
                                      Bad main board fixed mine. The power light was going out. fixed for $35
                                      • hbob17
                                        • Nov 2010
                                        • 20
                                        I just got done replacing the main board and it now has different symptoms
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • JohnML1975
                                          Falcon FF32S53 turns off by itself then will not turn back on unless you wait
                                          by JohnML1975
                                          Dear Forum members
                                          I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
                                          I will upload some photos and share my trouble shooting steps so far
                                          07-20-2025, 12:28 AM
                                        • ItepK
                                          LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                                          by ItepK
                                          Hello everyone! I've found this television, and I began troubleshooting it.
                                          First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                                          I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                                          After the recapping, all the voltages stableized, however, the issue in the title still remains.
                                          I could...
                                          01-03-2025, 09:01 AM
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • Daniel Larsson
                                          Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                                          by Daniel Larsson
                                          My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                                          I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                                          During these seconds the function button is not working...
                                          08-13-2025, 10:29 AM
