I have an insignia 37" lcd tv. when I turn the tv on the green light comes on and the screen flashes on for just a second and then it is black. the green light does stay on, but there is no sound. I have taken a flashlight and shinned on the screen and there is no video. I have tested all voltages coming out of the power supply and they are all correct. any help would be great thanks.
Insignia NS-LCD37 1 second to black
Re: Insignia NS-LCD37 1 second to black
did you shine the flashlight on the screen with a signal going to the tv? I have the exact same tv on my table right now. It has the exact symptom yours is having. The inverter board is a darfon with the typical bad inverter transformers. I'm waiting on ebay to get it fixed.
**EDIT**
I do remember having a harder than usual time shining the light on this tv. It took 2 MAG flashlights and a completely pitch dark basement. I hit the menu key and finally saw it.Last edited by Mr Bill; 08-05-2012, 09:42 PM.
Hi pictures would always help?, if it has "normal" darfon transformers you can test them on board - meter on 2000 ohms S1>S2 and S3>S4
Post results as
T1 S1>S2 =XXXOhms S3>S4 = XXXOhms
T2 S1>S2 = and so on.
Please also update your profile with Country and Mains VoltagePlease upload pictures using attachment function when ask for help on the repair
Can you post a picture of the inverter board?
It's half burried under the mainboard. Once you get a picture of it post the numbers on the top of the transformer. I ordered my transformer from ebay since it was only $7 and a used board was in the $40 range but it depends on which board you have. There are i think 3 different inverter boards used in this tv.
follow on from selldoors post,check all of the transformers,they all should be close readings,one that is different is a suspect.bloody darfons !fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
Hi Just been looking at transformers - if you click on buy it on the lcdparts it gives info
(does not mean you have bought it) Sec winding is over 2kohms to you will need your meter on higher 4K? 20K? ohms or autoranging if you have it.when you do the test.
http://www.ebay.com/itm/6008B-Invert...item25739de922
http://lcdparts.net/TransformerDetai...ProductID=3269
Suggesting where to buy from does depend on where you live.Please upload pictures using attachment function when ask for help on the repair
Did you check all the fuses on the inverter board?
There is one that looks like surface mounted resistor that most people overlook.Never stop learning
results
T1 S1>S2 =2.2k Ohms S3>S4 = 0k Ohms
T2 S1>S2 =2.2k Ohms S3>S4 = 2.2k Ohms
T3 S1>S2 =2.2k Ohms S3>S4 = 2.1k Ohms
T4 S1>S2 =2.2k Ohms S3>S4 = 2.2k Ohms
T5 S1>S2 =2.2k Ohms S3>S4 = 2.1k Ohms
T6 S1>S2 =2.2k Ohms S3>S4 = 2.2k Ohms
T7 S1>S2 =2.1k Ohms S3>S4 = 2.1k Ohms
T8 S1>S2 =2.2k Ohms S3>S4 = 2.2k Ohms
Looks like I just have one that is bad T1 has an open winding.
results
Well done - those darfons are a menace - designed to fail!!Please upload pictures using attachment function when ask for help on the repair
I know this is an old thread, but I'm having the exact same problem as the original poster and I've tested the transformers on my board and T7 came up with a very high reading (170k!) between S1 & S2. The rest of them came in around the 2.2k range.
Can anyone shed some light on what such a high number would indicate? Is it simply a matter of replacing that transformer?
Originally posted by cfsilence View PostCan anyone shed some light on what such a high number would indicate? Is it simply a matter of replacing that transformer?--- begin sig file ---
--- end sig file ---
