Samsung LE37A656A1FXXC bad panel?
  • magneh
    • Apr 2014
    • 595
    • Portugal
    Hello!
    Got this set from a friend and it has image issues.
    Opened it, checked PowerBoard voltages, all OK.
    Inverter 24V OK. 5V OK.
    All voltages present Ok.
    In some input's I got a normal image, but in antenna I've got a messed up image.
    First picture, when in EXT1, menu image OK.
    2nd one, when in EXT2, menu image OK.
    3rd one, when in antenna, image NOK.
    4th and 5th one, when scanning antenna signals, some "blurr" appears in the menu image.
    Share your thoughts guys!
    Thanks!
  • magneh
    • Apr 2014
    • 595
    • Portugal
    Re: Samsung LE37A656A1FXXC bad panel?
    Yo guys!
    No Samsung guru's in tha house?
    • Ltank
      • Jun 2013
      • 776
      If the screen was bad the menu would be bad but the menu looks fine so the screen and panel should be good. I think it's the main board
      • triplefour
        • May 2014
        • 1747
        if it seems like the problem is only with the tuner part, can u just replace that?
        Don't fear the repair...
        • Shinju
          • Mar 2014
          • 1239
          What does the image look like with HDMI ect?
          • magneh
            • Apr 2014
            • 595
            • Portugal
            Thanks for all the inputs!
            Gonna connect a HMDI source and take some pics!
            This TV has a Power Board, i/O board, 100hz board and tCon board.
            The culprit should be one of them...excluding the Power b0ard since all tensions presented OK...
            Gonna update later!
            • magneh
              • Apr 2014
              • 595
              • Portugal
              Hello!
              Well, I've got some inputs available and here are the results .
              picture1- back of the lcd
              picture2- hdmi input menu
              picture3 - hdmi connected, no image just one line in the bottom.
              When I select identify monitors on my laptop, I can see the 2 on the
              LCD but no image, just that blurry line on the bottom
              picture4 - ext1 by SCART connected in cable box TV. on the image of the start up of the cable box I can see some defects on the top of the image
              (some weird black stripes)
              picture5 - image on the cable box and I can see the image flickering and some blurry defects
              Exluding power board and inverter, the culprit could be 100hz board or main...
              Is it possible to troubleshoot these boards with MM?
              • magneh
                • Apr 2014
                • 595
                • Portugal
                Well I found a guy who is willing to sell me a new Mainboard and if it doesnt solve the issue with the LCD, he will refund.
                What do you guys think?
                Should I take this shot?
                Thanks!
                • Shinju
                  • Mar 2014
                  • 1239
                  Can you get into the service menu, TV off, hit Mute,1,8,2 in that order then power on.
                  Try and find the menu option for test patterns, DDR pre/post, FRC pre/post ect ect.
                  DO NOT change any settings outside of the test patterns, all changes you make are set in stone and cannot be wiped with a factory reset. The only way to do so is to go back in and change them back. (write down any options before you change anything so you can change them back).
                  If these issues persist in the test patterns chances are its a bad panel. Do this before you swap the new mainboard in.
                  • magneh
                    • Apr 2014
                    • 595
                    • Portugal
                    Hello!
                    Well, I've done the Mute+1+8+2 sequency and without pressing Power after, the set blinks twice and turns on, but the only thing I get is this (see pic).
                    • Shinju
                      • Mar 2014
                      • 1239
                      Have your HDMI device on and set the input on the tv to display that source then do the service menu and see.
                      • sordids999
                        • May 2013
                        • 2155
                        Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu
                        • magneh
                          • Apr 2014
                          • 595
                          • Portugal
                          Hello!
                          Ive done the Info+menu+mute+power sequency , got 4 blinks and the image turned on with the service menu for about 1 second and got back to those patterns like I posted on last photo.
                          Turned off. Tried again, 4 blinks and saw again the service menu 1 sec and image goes to that pattern :/ Damn.
                          • triplefour
                            • May 2014
                            • 1747
                            not that i have experience here but that single line of static across the screen doesnt look too comforting :/
                            is there any input that it does look fine on?
                            • magneh
                              • Apr 2014
                              • 595
                              • Portugal
                              Hello!
                              Well I've found out that there's only 1 input where I cant access the service menu after all.
                              If I'm on AV,HDMI,EXT or AV , I can see the menu!
                              I made a factory reset and no changes, as expected.
                              I cant find those test pattern DR pre/post, FRC pre/post Shinju talked about.
                              Here are some pics of the options I get.
                              1rst picture - menu
                              2nd picture - option table (service)´
                              3rd picture - checksum
                              Could it stil be a bad pannel? Or should I order the Mainboard and test?
                              Thanks!
                              • Shinju
                                • Mar 2014
                                • 1239
                                What was in the advance menu? BTW I think the menu system for Samsung outside of the US is not the same, as I have never seen a SM like yours before.
                                • magneh
                                  • Apr 2014
                                  • 595
                                  • Portugal
                                  On option 4 Advanced menu I cant get into any options.
                                  If I go to 1 I get into menu of picture 2.
                                  In option 4 I press OK but I cant get any options beyond.
                                  Cheers
                                  • magneh
                                    • Apr 2014
                                    • 595
                                    • Portugal
                                    Any thoughts why I cant enter any options on option4?
                                    Should I try another Mainboard?
                                      Press 0 four times on remote to access menu 4. Nothing much interesting there though.
                                      • magneh
                                        • Apr 2014
                                        • 595
                                        • Portugal
                                        Ok, so what should I do now?
                                        I cant do those pattern tests, and I dont see much where to troubleshoot next.
                                        Should I give up from this set ?
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          09-07-2024, 05:50 AM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Ierwin
                                          Samsung GU50TU8079U bad panel diagnosis
                                          by Ierwin
                                          I was given this Samsung GU50TU8079U that would power cycle after a couple seconds, sometimes a few minutes. The screen would turned cloudy dark with the backlight still lit and then the sytem would restart.
                                          Its one of the newer screwless Samsung models that I read a lot about panel failures here. It does not have a sperate T-CON board, just one ribon from the mainboard to the panel board and a U-shaped ribbon cable connecting the other half.
                                          I went through the usual diagnostics:
                                          unplugged the mainboard -> tv stayed on
                                          removed the U-Shape robbon ->...
                                          11-11-2023, 05:09 AM
