LG 60PK250/550 series Plasma; no standby
  • videobruce
    • Aug 2014
    • 16
    • US
    When power cord is inserted into a outlet all I get are two flashes of the power LED, then nothing. Completely dead. No clicking.
    The power supply, Y & Z boards all have been removed and inspected under a magnifying lamp for bulged caps, cold solder joints & burn marks and nothing found. All connectors were also inspected and reseated 3 or 4 times.
    Initially when the set died a repair shop came out and inspected the power supply board and 'hit' a few possible suspicious solder joints. The set worked for a month or so, then died again. What also was happening, the set could be left on for 2-3 days, but when turned off and later back on (unknown time frame) it wouldn't power up.
    They and I assume it's the PS board, but one huge problem is, there are no schematics that I can find on this series from Goldstar of theses boards. I have three similar service manuals, but the only schematics are for the control & main boards. No idea why Goldstar doesn't/didn't supply what should be in a service manual is beyond me.
    Anyway, any ideas here? I have done a fair amount of reading and I have seen nothing with the scenario.
  • videobruce
    • Aug 2014
    • 16
    • US
    Re: LG 60PK250/550 series Plasma; no standby
    The set is from 2010 and was left one for hours on end (a real poor practice) with no one watching. There was a fair amount of dust collected everywhere which was removed (not by a can of compressed air). The only discoloration I saw was on the reap internal cover. But, nothing I would consider unusual.
    Again, the boards were not discolored at all.
    • videobruce
      • Aug 2014
      • 16
      • US
      Would heating up (or freezing) any of the components help find the problem? I see that mentioned a number of times. Any component temperature issues were always running hot, not cold from my experience.
      • XCon
        LG 60PN6500 Plasma with standby, but won't power up.
        by XCon
        Symptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
        So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
        The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector...
        06-27-2025, 05:30 PM
      • rju
        Samsung 60" Plasma TV, Blinking Standby LED
        by rju
        A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
        Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
        Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
        07-21-2020, 05:23 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • check12
        Samsung Plasma PS43F4500AW Won't Start (flashing standby)
        by check12
        Hi ... Samsung Plasma PS43F4500AW ... when powered with 240V mains standby flashes, pressing PWR button causes standby LED to go out but nothing further happens.
        I have already removed and benched the SMPS, jumpered PS_ON to GND, VS_ON to 5.3v and have VS & VA voltages and all other voltages available at CN4007.
        VS=213v
        VA=58v
        SVT_VS=213v
        This suggests to me that the SMPS is probably ok but I have no experience of TV repair so could do with some help.
        I have removed the XY-Drive board and checked all the ribbon cable...
        11-21-2021, 07:46 AM
      • 7ony
        Samsung plasma - flashing standby light
        by 7ony
        The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
        Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
        Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
        No visible...
        08-31-2020, 05:18 PM
