17mb60-4 firmware
  • iuliantv
    • Aug 2009
    • 36
    17mb60-4 firmware
    Hello, I have a big thing to ask you, have a lcd tv, ALBA LED16911HD that has software problems, motherboard is Vestel 17mb60-4 I tried several versions of software toshiba, sharp, but the software image is negative, or divided into four parts, it seems that the problem is due to the 16inch display resolution, 720p, mounted on the tv, I'm interested in a firmware that contain rules bg dk UHF VHF VHL, thank you and please excuse my English, I use e Translate goo ...
  • iuliantv
    • Aug 2009
    • 36
    Re: 17mb60-4 firmware
    • senndogg
      • Dec 2011
      • 383
      • Albania
      Please update your info and dont make your email public. firmware for unknown brands is always hard to find, i wish you luck in that.
      • iuliantv
        • Aug 2009
        • 36
        thank you for clarification, I complemented location, same motherboard uses the same 16-inch LED display and TELETECH 16912, Saba 1600jc , Telefunken TE16912B17, Vestel 16vh3021,and do not think that I am alone, all the best
        • iuliantv
          • Aug 2009
          • 36
          maybe someone knows a method for extracting functional software on a TV without the need to remove the flash memory on the motherboard, through RS232, JTAG, USB. all the best
          • Kilroys
            • Feb 2014
            • 70
            • Sweden
            What kind of lcd panel is there in your set.
            CMO, AUO or LG ?
            No DVD ?
            There is a label on the rear with modelname
            and bar-codes.
            Obove the the codes there are numbers.
            Perhaps one with 18 numbers .
            There are no method for extracting the software
            • iuliantv
              • Aug 2009
              • 36
              no dvd,17MB60-4 100211 CPTWB11 CLA156WB11
              • FIXITNOW
                • Jun 2008
                • 128
                usb stick 17MB60 to cure Flashing Front LED fault which is now getting very common
                Could all members do this when they see one of these sets
                This is how to
                Plug empty USB Stick in to usb port (must be empty else will try coping file from stick into tv !!)
                Switch on set Access hidden Menu by
                Pressing MENU button then 7935
                select
                Copy NVRAM data
                You should get 2 to 7 bin files maybe more
                Please put these into zip file with a text file holding info
                Info need
                Make of set
                Model number
                Board number for instance 17mb60-1 or 17mb61 or 17mb70
                Screen type and part number
                Product Code on the back Label for instance 37654321
                If you get a working set saving this will help otheres with Flashing Front LED fault
                To save a set to your tv copy correct file to usb stick plug into turn tv on via mains while holding down ok button on remote
                Remember Data is unique per Model
                • FIXITNOW
                  • Jun 2008
                  • 128
                  vestel tech note for mb70
                  so works on mb60 mb61 and mb70
                  also note this need P+ button instead of ok button on remote
                  so best to try both if trying to upload file
                  if OK button not work try again with P+ button
                  • FIXITNOW
                    • Jun 2008
                    • 128
                    iuliantv@yahoo.com
                    please up load firmwares you have in zip file with extra info
                    Info need
                    Make of set
                    Model number
                    • zwarder
                      • Oct 2013
                      • 46
                      Does anyone have 17mb70-5p firmware for sharp Lc40LE511E. I have got it to boot but doesn't recognise remote or touch panel.
                      Had to heat cpu to get boot would a reflow cure the remote problem
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        https://www.arizanotlari.com/2019/03...71-17mb75.html
                        https://www.badcaps.net
                        • jellytot
                          • Mar 2015
                          • 42
                          • Ireland
                          arizanotlari: I just visited your Site. Very helpful information
                          Thank you for your work..
                          • jellytot
                            • Mar 2015
                            • 42
                            • Ireland
                            Hi arizanotlari. I have a JVC LT-40C860 uhd led tv Mainboard 17MB120 It is in a
                            boot cycle and I think the nand is corrupt the JVC logo comes on in a constant loop. I have searched the net but cant find the software files to restore as explained in the 17MB120 chassis pdf.
                            1. mb120_en.bin, RomBoot.bin, PM51.bin and usb_auto_update_G6F.txt documents should be copied directly
                            inside of a flash memory (not in a folder).
                            2. Insert flash memory to the TV when TV is powered off.
                            3. While pushing the OK button in remote control, power on and wait. TV will power-up itself.
                            4. If First Time Installation screen comes, it means software update procedure is successful.
                            Any thoughts? If I could get a nand dump It might work also
                            • arizanotlari
                              • Nov 2014
                              • 158
                              • Turkiye
                              Hello.
                              for rewrite nandflash you need programmer.
                              for usb upgrade : https://yadi.sk/d/YY_0QmW3sezsDg
                              sorry my english
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                08-11-2025, 02:14 PM
                              • TheUser
                                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                by TheUser
                                Hello to everyone ,
                                This is my first post here, and i would like to share with you a small story in case you can help me.
                                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                02-10-2024, 02:07 PM
                              • gurj1979
                                Ubiquiti firmware help. US-8-150W POE
                                by gurj1979
                                Hi guys.
                                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                Got New chip and writes good.
                                THE PROBLEM...
                                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                Does anyone have a Good Firmware I can have?...
                                07-22-2024, 05:13 PM
                              • Slapito
                                Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                                by Slapito
                                I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                                Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                                I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                                I already downloaded the BIOS update file from msi official...
                                10-09-2025, 02:00 AM
                              • wattage
                                by wattage
                                Hello Badcaps Community,
                                07-13-2025, 04:41 PM
