Vizio LED xvt553sv
  • mnpdreed
    • Sep 2014
    • 122
    Re: Vizio LED xvt553sv
    Here is the amber led on back of led driver board
      You are not having backlights problem, the T-CON is not getting the the Voltage to run.
      • mnpdreed
        • Sep 2014
        • 122
        Ok my bad. The cable in main board was not seated well here is the new reading. Same on both sides 106.8 mV
        • mnpdreed
          • Sep 2014
          • 122
          The backlight is on just no picture or sound
          • mnpdreed
            • Sep 2014
            • 122
            What voltage should be there?
            • mnpdreed
              • Sep 2014
              • 122
              Pic of main board
              • mnpdreed
                • Sep 2014
                • 122
                Main board fuse readings
                F1 12.28 V
                F3 5.09 V
                F8 18.34 V
                • mnpdreed
                  • Sep 2014
                  • 122
                  F1 12.28 V
                  F3 5.09 V
                  F8 18.34 V
                    per spec, it should have 12VDC.
                    http://www.lcdsolar.com/products/Pro...8#.VC2qG_ldV8E
                    • mnpdreed
                      • Sep 2014
                      • 122
                      Do you have any suggestions on where to check the main board as to why it isn't reaching TConn
                        Well, without the diagram, you will have to trace out using Ohm meter from one end of the fuse on the T-CON board to the main board to find out which component has the lowest resistance reading, that will be the switching device (more likely to be MOSFET).
                        I will guess some thing in that red section I marked.
                        • mnpdreed
                          • Sep 2014
                          • 122
                          Ok will do that and get back with you. Thank you for the help
                          • mnpdreed
                            • Sep 2014
                            • 122
                            I just found out from the guy I got the TV from that when the TV first stopped working having no picture or sound that he bought a refurbished main board and installed and had same results. Based on what you see so far do you think the problem is in main board.
                              Yes, the new board can be bad, you will not really take the word of the seller that the board is good or bad for sure.
                              • mnpdreed
                                • Sep 2014
                                • 122
                                I traced from TCon to main board then to where the ribbon comes from the power supply to the main board . Only had 5 volts on three pins all other read m volts. Traced ribbon to power supply same readings.
                                • mnpdreed
                                  • Sep 2014
                                  • 122
                                  So I'm losing the voltage at the power supple I think. Do you have any advice from here
                                  • mnpdreed
                                    • Sep 2014
                                    • 122
                                    Her is pic of power supply
                                    • mnpdreed
                                      • Sep 2014
                                      • 122
                                      On "CN202" the right three pins read 5.1 volts. All others read in milivolts
                                        The ribbon cable from the T-CON on the pin that the 12V from the main board is fed into will get the 12V through a switched device (3-pin device), that is the device you need to find on the main board.
                                        • mnpdreed
                                          • Sep 2014
                                          • 122
                                          Ok I will try and find it but I'm not getting the 12 volt at all from the power supply would that matter
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
