Panasonic TC-P46S1
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P46S1
    Originally posted by splitcrete
    I have been trying to solder thin wires to the transistor,
    but it is so small. Any ideas ? The board had a crater where it was once soldered.
    I can't do a trade in because the board is damaged. What now ?
    I was thinking along the lines of prototype board, solder the transitor on that, maybe also the resistors and recreate the cct, then scrap all that black stuff, maybe even cutting the tracks away a little, then sicone the proto board in place and jumper from the board to the relevant tracks,
    You can get a blade cut the tracks on the proto board, I guess finding something with the correct spacings for the transistors pins,
    You just need a little imagination and then care replicating the cct, links etc but should not be impossible for you to figure out.
    • tw2005
      • Oct 2011
      • 6458
      Actually finding the right spacing will be an issue, there must be something out there
        A little IPA would remove the burnt carbonisation, with that you could probably see the tracks better, just a thought.
        • tw2005
          • Oct 2011
          • 6458
          Looks a pretty bad burn. I had a similar situation on a 5081 with a smd diode, quite incredible how deep and the tracks lifted/fused. dug it out, filled it with epoxy but with this transistor, pretty fine pitch and not sure what is left of the tracks if any where that sat.
          Anyway where there's a will, there's a way. Soldering wires to the Transistor though I think near impossible, don't like that idea.
            If it's some kind of dual transistor array, maybe he could just replace it with two through hole transistors.
            • tw2005
              • Oct 2011
              • 6458
              It's a npn/pnp
              • splitcrete
                • Dec 2012
                • 387
                • usa
                #27
                I ordered a new board. the traces were to burned to fix. Will let you peeps know what happens with a new board. Thanks for all the help.
                • splitcrete
                  • Dec 2012
                  • 387
                  • usa
                  #28
                  Soldering wires to the Transistor Was very easy with the right magnification .
                  It was burned under the traces, and I was going crazy trying to find a place to solder on.
                  So now the replacement board from China.
                  • splitcrete
                    • Dec 2012
                    • 387
                    • usa
                    #29
                    The traces looked good but they were non conductive .
                    • Jooo
                      • Oct 2011
                      • 222
                      • Finland
                      #30
                      You would have needed to scrape off the soldermask with a flat head screwdriver or a knife before soldering.
                      • splitcrete
                        • Dec 2012
                        • 387
                        • usa
                        #31
                        Back to this set,sorry its been a wile. Jooo thanks for the pics, your pic is spot on. I have the print now. I can use 4 of the traces . Micro surgery after that lol. will post back when solder job is complete.
                        • splitcrete
                          • Dec 2012
                          • 387
                          • usa
                          #32
                          That board from China I canceled it , I have two of the five traces soldered . Next two will be easy,but its the middle trace that goes to R-421 is going to be the one . That is the trace that went under the Q-521 to R-421
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            #33
                            I gave up on fixing the SC board. I got a board from e-bay for a TC-P50S1
                            TC-P46S1 It works just fine now. So TNPA4782 AC ... Can be replaced with TNPA4782 ...AB
                            46" 50"
                              hm, be careful because ER inductors are different it may blow SC or you may get pink-out on bright images (or blue-out on dark ones...)
                              • splitcrete
                                • Dec 2012
                                • 387
                                • usa
                                #35
                                The boards are almost exact only to caps different . Nothing getting hot picture is spot on . If it blows up I will post back with a damage report...
                                • splitcrete
                                  • Dec 2012
                                  • 387
                                  • usa
                                  #36
                                  Day 2, This TV is still working great.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    you could simply compare the 2 board part lists and swap over the different caps and also inductor coils are usually different between panels
                                    • splitcrete
                                      • Dec 2012
                                      • 387
                                      • usa
                                      #38
                                      My thinking is that I went from 46" sc board to 50" sc board the inductors, and caps would be of a higher value. I would never try it the other way around. So far it is running perfect I don't think I will have a problem.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        It's more about impedance matching the load i.e. the panel so has nothing to do with the electrical value.
                                        I don't know what the long term effect would be if any?
                                        The only thing you'd have to watch with this is being sure the same amount of transistors and the same type as they can vary as the size increases the load goes up which is why you see unpopulated locations on the boards.
                                        • splitcrete
                                          • Dec 2012
                                          • 387
                                          • usa
                                          #40
                                          I went over the board don't think I missed any thing, every thing was the same except the caps. The inductor coils were the same I will post pics as soon as I get a chance.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • nervx
                                            Panasonic TH-42PZ800 8-blink error mystery
                                            by nervx
                                            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                            04-08-2022, 05:19 AM
                                          • SentraDude
                                            (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                            by SentraDude
                                            Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                            I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                            Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                            04-04-2023, 04:24 PM
                                          • rmacintosh
                                            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                            by rmacintosh
                                            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                            The symptoms of the tv ar as follows:
                                            • Plug AC in to back of TV
                                            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                            • The 3 blink code is given by the power LED
                                            • If the TV is unplugged and then
                                            03-14-2020, 12:24 AM
