Samsung LN40D630M3FXZA Has Backlight and Sound, No Picture
    Re: Samsung LN40D630M3FXZA Has Backlight and Sound, No Picture
    Yeah, looks like it. Sad to see another panel bad!
    • kevinm34232
      • May 2012
      • 1884
      I've seen those looking for what part # QD2 is on many Samsung T-Cons. I replaced the shorted QD2 on the original T-Con with part# ZXMN6A07FTA MOSFET N-CH 60V 1.2A SOT23-3, and it worked. Unfortunately it confirmed the panel is bad as the image was same as above.
        Panel might have initially caused fault, then whatever was shorted went open circuit. Transistor was damaged in that fault condition.
        • nomoresonys
          • 12206
          • U.S.
          too bad about the panel but a very nice tcon fix.
          • pudgi300
            • Nov 2008
            • 35
            would anyone know the p/n for the fet with marking 58A. It is used on many tcon boards. It is p-ch 6pin
            • pudgi300
              • Nov 2008
              • 35
              #26
              Looks like i tracked it down to FDC658A made by fairchild.
              I got my Sony KDL-40w4100 Tcon board working after replacing the following parts.
              F1 7amp fuse
              cd 201 10uf cap
              D14 sot-23 switching diode marking KJH MMBD7000 DIODES INC 2 DIODES IN SERIES (1 WAS LEAKING)
              IC11 FDC658a digikey FDC658APCT-ND
              I ALSO REPLACED IC21 TPS65167A BUT ONLY REPLACE IT IF IT IS BAD. I FOUND ONE ON AN OLD MITS TCON MADE BY SAMSUNG.
              HOPE THIS HELPS SOMEONE REPAIR THEIR TV
              • Recyclojunk64
                • 6
                Hi, I am trying to repair a Hisense HL46T39PZLN3D LED-backlit display with a similar problem.
                Transistor QD1 on T-con board SD120PBMB4C6LV0.0 is not turning on (12V on gate), it's gate capacitor is not shorted, and transistor QD2 is not shorted/burned. I could not figure out where the gate-signal for QD1 goes to as the trace disappears into the middle layers of the board and couldn't find a connection.
                I attached a wire to temporarily bypass QD1 just to see if the panel is damaged before ordering a replacement T-con board (or trying further to repair the existing one). I connected the wires after the TV had turned on, and this is what comes up on the panel:
                After about 30 seconds it slowly fades to this:
                Then goes back to the original as soon as the jumper wires are disconnected and reconnected.
                Is it likely to be a problem with the display panel? Or simply because the T-con board was not initialised properly? I don't have that much experience repairing TVs so don't really know what a defective panel looks like.
                Thanks for any advice.
                Edit: Full size images below.
                • Recyclojunk64
                  • 6
                  Hmm..., noone has seen an LCD displaying a pattern like this before? I would really like to know whether it's worth replacing the T-Con board to see if that fixes it or whether these are the symptoms of a failed panel and I should just toss it to make more room on my workbench.
                  I have a digital scope btw if there's anything else I could test for...
                  • steves7839
                    • Nov 2014
                    • 200
                    Sure looks like a T-Con symptom. I'd buy one from a seller accepting returns if possible.
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • LaPCon_IT
                      Samsung UE50TU7099U no picture no sound, backlight present
                      by LaPCon_IT
                      TV has one combo board (VTT55UH160). Symptoms are like this.
                      When part of the screen is disconnected (white part), it looks like this
                      Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
                      I haven't noticed any shorts on rails listed below:
                      VGH - 30V
                      VGL- -9V
                      VAA - 14V
                      VCOM - 5.6V
                      STV - 11.95V
                      LC1, LC2 - +30/-12V
                      All CKV lines (no shorts between them) looks the same:
                      I've tried to cover some lines with...
                      12-15-2023, 03:55 AM
                    • henry21347
                      Samsung LN52B550K1F no backlight has picture has sound
                      by henry21347
                      Hi I have a samsung LN52B550K1F LCD TV. There is no backlight but I can see a picture under a flash light. The sound is playing as normal. I have attached the pictures of the boards.
                      With my laptop connected to HDMI4 port, I tested the voltages of the connectors:
                      Power board (BN44-00267B) to main board (BN97-03035M) connector (CN801):
                      5V_DET 0.1V
                      E-PWM 2.77
                      I-PWM 0
                      INV-ON 0.05
                      13V 12.81
                      5.1V 5.15
                      SB 5.2V
                      PS 1.22
                      SYNC 1.74
                      Power board to LED driver board (SSB520H18V01):
                      VCC...
                      12-23-2022, 12:29 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
