Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational, Take 2
  • CoppellTVRepair
    • 47
    There's a thread on the site titled "Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational", detailing the process of the most common problem affecting power supply board PSD-0888D.
    For the sake of bringing something of value I'd also add (even though it probably belongs in the thread itself) that what's described there is one of the TWO possible variants of the failure - blown IC, blown fusable resistor 2.2 Ohm or 2 Ohm.
    The other is an internally failed, but not shorted IC, resulting in resistor that's still intact, but the board spontaneously losing power after anywhere from a few seconds to a few minutes of operation.
    In other words, when in doubt, always replace the IC. (in fact I personally simply always replace the IC, whether doubting or not - it's fast, easy, cheap and insures client won't come back during warranty because of an aged and finally broken IC...that's my general philosophy and approach to all common failures).
    This post is about a problem that gives almost the same failure symptom, but definitely has a different origin, which, for the life of me, I can't figure out.
    What is happening is the board starts, the relay clicks, the PFC raises momentarily to somewhere above 300V - like 310V or so, but not 380V-400V it should go, at least not by the Fluke, the secondary DCs all show up as they should and then, practically immediately, the PFC starts going down, apparently turned off.
    The PFC driver is UCC28061 and it is definitely not the issue.
    It's been a while since I last spent a night chasing this before giving up, but today yet another one of those board showed up with the same issue.
    Unfortunately I can't find my previous notes, but I do remember I found the following: If I cut a certain track of an IC in the surroundings of the PFC driver the PFC stayed on and produced 396V as it should.
    I got to this track while chasing the signal causing the shutdown, but that's what I remember from it...and the suspicion it may be some of the high voltage dividing resistors to have gone off and cause all this.
    This is one of those nasty issues where things aren't exactly failed so you can just track down the short and take care of it (not that those can't have nasty side issues to kill your sleep, but it's less often).
    It's luckily not a problem where you have to wait an hour for a spontaneous shutdown either - it's quite persistent and reproducible.
    Yet in several multi-hour attempts over the pat few months I've failed to nail it.
    Any help will be appreciated and I wouldn't at all mind paying for the knowledge...I am by no means novice to electronic repairs, but I don't quite consider myself professional either, even though most people probably would consider me such.
    It's just that I know real professionals and I know I am not their level...and likely never will be.
    I am just someone who usually finds solutions to problems and this one I so far can't.
    TIA,
    Bobby
  • CoppellTVRepair
    • 47
    Ah, forgot to say...the cut track, while keeping the board up and keeping the PFC does not appear to be a solution to the problem.
    I do not have the whole TV, unfortunately, I do most power board repairs merely bench testing.
    I believe I've tried that hack with a customer once before and they reported it didn't fix the TV; could be the hack is not sufficient, could be the TV had other problems too.
      • 12335
      • U.S.
      Can you post a picture of the top of the board? You're sure that it's not a capacitor issue?
        • 12335
        • U.S.
        Here's Nick's fixing a board, might help: https://www.youtube.com/watch?v=EZfsaGlJPX4
        • CoppellTVRepair
          • 47
          No offense meant and definitely not trying to start a war here or even a pissing contest, but Nick used to send us boards he couldn't repair and follow our videos for clues...not sure if he still does, it's irrelevant.
          However it may sound I am keen on believing I sill have the technical edge on him.
          He's a good kid, nothing against him whatsoever, it's just I really and honestly do not think I can learn how to repair power circuits from him. Still repairing an occasional XVTx73SV main board with NTR stamp on it :-)
          But this one has me stumped and I am of the opinion there are at least a few people on this site that are at least a level above me and will always be.
          For the last time, no offense meant to anyone...I just call it as I see it and fully aware I could be wrong. Has happened more than once in the past, but life's too short to be modest.
          • CoppellTVRepair
            • 47
            I thought it would be kind of pollution to just upload pictures that are already there...should have included the link to the post I was referring to, sorry...it has all the pictures already and what's missing I can upload:
            https://www.badcaps.net/forum/troubl...ot-operational
            I can also draw up the schematic from the board...I know I did at some point and found at least one instance of a bad high voltage divider resistor...which is why I suspect one of those.
            If it is a cap it is highly unlikely to be a standard electrolytic one. The usual suspects have all been checked and/or replaced - it's frankly easier to replace them than to bother ESR checking.
            I've seen similar behavior in other power supply boards and never got the hang of what's causing it...it's almost as if the voltage does not raise fast enough and it may be UVP that kicks in...but that's a speculation based on my mind trying to fit an explanation.
            I posted yesterday without preparation because I remember the last time I spent like 4-5 hours between a working board and a bad one and eventually gave up hoping I'd just never see one of them again...but sure enough I did and there's a customer waiting to get their TV working.
            And I just hate failures....who doesn't :-/
            • Diah
              • Feb 2013
              • 6647
              the cutting Track of Q7204 to keep PFC mean fault on it
                • 12335
                • U.S.
                Indeed Bobby, I've seen your videos too. You and Nick have a great depth of knowledge, no doubt about it. I'm not a pro, just enthusiast, I usually forget things as fast as I learn them. I remember seeing a similar situation where the cold side was outputting proper voltages but not the pfc. In that particular one if I recall it was a problem in the feedback circuit but damn if I can remember exactly what.
                • CoppellTVRepair
                  • 47
                  Not necessarily, the best proof of which is that the PFC *is* working when the track is cut.
                  I may get back to the drawing board once I do the other tasks...which kind of never ends, especially now that I am back at writing software (which is a lot of fun I've recently lost reverse engineering electric circuits), but in the meantime I believe I've cut either the final or at least one of the feedback signals that shut down the PFC...like OVP and UVP.
                  So it might not be the PFC itself that is bad, it may be the watchdogs or it may be simply (and that's what I think) that it's just that the output voltage is raising slower than expected or with more fluctuations, so a watchdog may be incorrectly triggered.
                  Or it could be that one of the secondary voltages is raising too slow for same or different reasons. I already forgot what I conclude the last time, but my memory is I suspect the high voltage dividers in the PFC circuit and have stopped looking at the secondary side...though they are ultimately all added up as one suppress signal to the PFC driver.
                  • Diah
                    • Feb 2013
                    • 6647
                    you are mixing 2 different shoes in one legs..
                    watchdog had nothings to do , or any part of Firmware.. its PFC you have value changed ( raised up ) of one R at circuit..
                    • CoppellTVRepair
                      • 47
                      My terminology may be wrong...as I said I am back into software and happen to be implementing watchdogs currently...sorry.
                      But in the electronics field I call "watchdogs" the circuits responsible for monitoring various failure conditions (OVP, UVP, lack of secondary), which all could cause the PFC to shut down. They may not be "active" watchdogs as in the software world and again my terminology in that regard may be incorrect and misleading, for which I apologize.
                      My logic was to exclude (hack) all possible sources of the PFC shutting down thus eventually discovering which one of them is causing it....and that's what lead me to this track.
                      By no means I intend to argue, I am just sharing my thought process and am certainly open for education.
                      • lotas
                        • Jan 2016
                        • 4969
                        • Russia
                        Maybe something will help
                        Check, replace this string of resistors... Over time, the "glue" under these resistors starts to leak.
                        • Diah
                          • Feb 2013
                          • 6647
                          My logic was to exclude (hack) all possible sources of the PFC shutting down thus eventually discovering which one of them is causing it....and that's what lead me to this track. By no means I intend to argue, I am just sharing my thought process and am certainly open for education.
                          watchdog / E-Fuse are listed at TV, but they are much tricked on MICOM / Controller / SoC at MB when there are SOS signal come from other parts such like T-CON..
                          for example we switch off Watchdog at NVM within Philips OLED TV... to let the TV remain on if there celle on OLED Module pull more currents.
                          yours work now only PSU on bench with out other TV Parts like swimming in ocean to reach dream land.
                            • 12335
                            • U.S.
                            Maybe a bad opto.
                            • R_J
                              • 9638
                              By cutting the trace you have disconnected Q7204B base, Q7204B emitter should have 16vdc (vcc voltage) and its collector voltage would be set by ic7202, I suspect Q7204B collector is going high and that turns on the base of Q7204A, which conducts taking ic7201 pin2 (vsense) low shutting it down. I suspect under normal conditions Q7204A would be turned off so I would check the resistors etc around ic7202 or ic7202 might be bad?
                              Also make sure your vcc voltage is 16vdc A weak C7114 or C7226 could cause high frequency noise on the vcc line
                              With the trace cut and pfc working you likely have around 6vdc on ic7201 pin2 with the trace connected I suspect that voltage is near 0v because Q7204a is turned on.
                                • 12335
                                • U.S.
                                Any update on this Bob?
                                • CoppellTVRepair
                                  • 47
                                  It was one of those weekends where I had to work both days on unique problems for overdue customers...first time (out of easily hundreds) seeing audio IC go bad on LG 55LV series, first time Samsung BN44-01264A repetitive failure, first time Vizio M60-D1 (I think) main board failure...I just never made it to the Sharp.
                                  Did I also mention I am in the meantime writing software at night? :-)
                                  This week will be dealing with the Sharp.
                                  My plan was to replace the high voltage resistor dividers, but I also want to measure and confirm what @R_J was talking about as his language is the closest to what I refer to "someone who knows this stuff".
                                  If anyone has the schematic post it or DM me if you have concerns posting it in public.
                                  I will give update as soon as there is one.
                                    • 12335
                                    • U.S.
                                    ^^^ knows it ALL so needs no help.
                                    • R_J
                                      • 9638
                                      check post 12 for the RUNTKA903WJQZ schematic
                                      • scubacamper
                                        Sharp Aquos LC-70C6400U Half Screen Dark
                                        by scubacamper
                                        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                        05-03-2025, 12:19 PM
                                      • sefoster
                                        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                        by sefoster
                                        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                        11-20-2022, 09:29 AM
                                      • jonah1024
                                        Sharp Aquos LC-40UG7252E LCD TV burn in?
                                        by jonah1024
                                        Hello!
                                        I'm a few days old into this TV screens repair universe so please bear with me.
                                        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                        - I did a factory reset as well...
                                        07-16-2024, 04:23 AM
                                      • klassic
                                        Sharp Aquos LC-60LE635E three blinks
                                        by klassic
                                        Hi community,
                                        I will describe my problem with a TV in those short following terms to be the most precise :
                                        What i have :
                                        power board DPS-162KP-1
                                        main logic board QPWBXF733WJN2
                                        symptoms :
                                        white led light logo at startup,
                                        after 2 minutes, blinking 3 times a row, repeating
                                        no backlight (and apparently no picture, checked panel with flashlight)
                                        no startup sound
                                        powerboard investigations :
                                        1-2 PNL : 0v
                                        3-4 GND
                                        5-6-7-8 UR : 13.15v
                                        9-10-11-12...
                                        10-24-2023, 01:39 PM
                                      • kca
                                        by kca
                                        Hello all ~
                                        I picked up this nice Sharp Aquos 80" television the other day but when I plugged it in nothing happened. And I mean nothing. No picture, no sound, no logo, no LED lights on the front panel. Nothing.
                                        So, I opened it up and the only thing I could detect using my multimeter was the fact that it was receiving and passing along the 120 AC volts from the plug and I was also able to determine that the glass fuse that's near the plug-in appeared good and it was registering 45.4 AC volts. Not sure if that number indicates that the fuse is good or not....
                                        08-26-2020, 08:28 PM
