Question about jumpering P.S.-on command
+ More Options
Posts
  • Ltank
    • Jun 2013
    • 776
    Re: Question about jumpering P.S.-on command
    Corrected Drawing
      https://www.badcaps.net/forum/showth...381#post485381
      OK, I see that too now in the picture, the white bar (CATHODE) is on the right and connected to the + of C7912.
      That Q1 has nothing to do with the VCC to the PFC IC though, so we still need to find out where that voltage supply is.
      • Ltank
        • Jun 2013
        • 776
        Pin #7 of 3BS3LJ is 16.21 dvc as come from the Emitter Q7916 comon base circuit. this is the VCC to that IC
        IC 7801 1608B and IC 7601 DDA002C in the primary circuits have no VCC I will start in those circuits.
        • Ltank
          • Jun 2013
          • 776
          The Customer said it displayed one long and one short led on front panel but it never came on for me. I have seen post elsewhere That one long and one short was either a bad Power Supply or a Bad Panel. Because I could not jumper it on I fugured it was a Bad Power Supply.
          Well I received the 2nd New Power Supply and it to will not turn on. The Original and the 1st New Power Supply would not turn on when Jumpering the 5 volts to PS-On.
          The 2nd New Power Supply does the exact same thing.
          Then I thought that maybe the LEDs was the problem that the Power supply was not sensing the correct load. There are not any voltage or current markings on the power supply. I could not measure any reisitance across any of the pins in any combination or polarity. I have Samsung Led TV waiting on a Main a Main Board and its LEDs light when the power suppy is jumpered on. I tried measuring the reisistance on that LED panel and also got no reisistance with any combination. I have to eat the cost of this Power Supply. They will exchange it for a Defective part but not refund due to a mis diognosis.
          Any one know how to test LEDs at the connector without taking apart the screen?
          • gamethriller
            • Oct 2014
            • 153
            I have the same set and traced the one slow blink one fast blink to a bad led in the panel. I have fixed that problem but can not figure out how to clear out the error count to 0 to turn it on. Any ideals? It says in the manual the counts are cleared to 0 by the settings in the process A????
            • Ltank
              • Jun 2013
              • 776
              There should be a listing somewhere on this site to reset to factory settings. Maybe that would reset it.
              • ktmmotocross
                Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                by ktmmotocross
                Acer 515-54G
                DA0ZAWMB8G0
                Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                i dont uderstand this. Charger ic BQ24780S
                ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                What is pulling my ACDET down when i apply power even without BQ ic...
                12-02-2022, 12:03 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
