RCA (Thomson) F20TF10 in a coma
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #81
    Re: RCA (Thomson) F20TF10 in a coma
    digikey for both and choose first class shipping .
    Originally posted by SteveNielsen
    I can get the regulator from Parts Express (and too much in shipping) but haven't found a source for the fuse yet.
    • SteveNielsen
      Retired Tech
      • 2327
      No need to at this point but thank you.
      • SteveNielsen
        Retired Tech
        • 2327
        In the interest of time I did not repair this 2nd MP50 fuse but used a .5A glass fuse with leads for troubleshooting. After replacing fuse there is NO high voltage on the anode and I can hear HV hiss from somewhere.
        • kasfamily
          • Aug 2014
          • 772
          • Russia
          #84
          Turn off the light and in the dark it will be seen place leak
          • SteveNielsen
            Retired Tech
            • 2327
            I can't see it in the dark but it sounds from the area of the 6v regulator, the hiss sound changes over a period of 1/2 second from quiet to louder quickly then down to quiet again.
            • kasfamily
              • Aug 2014
              • 772
              • Russia
              #86
              You do not forget to connect the ground wire from the CRT to the U02 on the CRT board ?
              • SteveNielsen
                Retired Tech
                • 2327
                I did not forget, it is connected and confirmed good to mainbaord ground as well.
                I checked with KV probe on connections in the area of 9 and 6 volt regulators (area where the hiss sound originates) with no results.
                I pulled one leg for the fuse and got HV back on the CRT anode.
                • kasfamily
                  • Aug 2014
                  • 772
                  • Russia
                  #88
                  Probably some sort of a bug in the installation. Clarify in there circle you're talking about the fuse
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    This pic is before replacement.
                    • kasfamily
                      • Aug 2014
                      • 772
                      • Russia
                      #90
                      Need to check the electrical circuit of the fuse and measure the resistance of the stabilizer 7806 pin 1-ground, and pin3 - ground. And show the actual photo.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        The fuse ckt is ok. 7086 pin 1 is 1.1M to ground and pin 3 is 4K to ground. Fuse is circled, 7806 has the arrow.
                        • kasfamily
                          • Aug 2014
                          • 772
                          • Russia
                          #92
                          What news? I want to show fuse repair
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            The MP 50 below the fuse circled in the 2nd pic is the repaired fuse, the fuse wire I used from a glass fuse goes around the outside of the body on the right side. That checks ok.
                            • kasfamily
                              • Aug 2014
                              • 772
                              • Russia
                              #94
                              I see it. Now what is missing, all the voltages are?
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                UB on mainboard has changed from 117.9v to 136.5v
                                CRT pins 11, 8 & 6 has changed from 177-180v to 102-105v
                                CRT anode has 0v
                                VG2 has 75 to 534vdc to 0.0v to 0.1v rotating screen control
                                BU004 pin 5 changed from 188.8v to 134.9v
                                BU003 pins changed:
                                2 was 1.2v now 0.3v
                                3 was 1.2v now 0.3v
                                4 was 1.2v now 0.3v
                                6 was 8.7v now 0v
                                Mainboard 12v, 9v & 6v test points are good.
                                I am thinking again it is some part in the flyback assembly.
                                • kasfamily
                                  • Aug 2014
                                  • 772
                                  • Russia
                                  #96
                                  Check the voltage IV01 (TA1268) 1: - 9 volts on pin 9,26,46,48. 2: - 3.3 volts on pin 18
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    26 has .7v
                                    48 has 0v
                                    The rest are ok.
                                    • kasfamily
                                      • Aug 2014
                                      • 772
                                      • Russia
                                      #98
                                      Pin 26 (IV01) is power a master oscillator flyback , it is necessary to check the resistance pin 26 on the ground. Trace the entire chain of the pin 26, there should be a zener diode and probably low-resistance breaking resistor from pin flyback
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        There is no conductivity from IV01 pin 26 to ground.
                                        The zener checks ok out of circuit.
                                        The resistor is 2.2 ohms out of circuit.
                                        Traced to emitter of TP390, an NPN that tests good out of circuit. The base ties to 9VS2, which has tested good when powered.
                                        That is as far as I've gotten so far.
                                        • kasfamily
                                          • Aug 2014
                                          • 772
                                          • Russia
                                          #100
                                          Collector TP390 what is connected, you can see how the chain? I'm on a photo I can not check, fuzzy printing, may be even take a picture of this area from two sides. Principle of operation is that when the power is turned on the first 26 pin comes from the power supply, and when it begins to run flyback line scanning, the power to pin 26 comes with flyback
                                          • edugimeno
                                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                            by edugimeno
                                            Hi!!
                                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                            At a certain point, moving stuff around, I put all wires back in place and...
                                            03-24-2024, 02:31 PM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            by sam_sam_sam
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                            Thomson NEO 17 N17CSL512V3SM Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO 17 N17CSL512V3SM Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N17CSL512V3SM boardview and N17CSL512V3SM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 06:21 AM
                                            Thomson NEO X14C WWX14C4BL64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4BL64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4BL64-P boardview and WWX14C4BL64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            Thomson NEO 15 WWN15I5-8BK1T Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO 15 WWN15I5-8BK1T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWN15I5-8BK1T boardview and WWN15I5-8BK1T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
