RCA (Thomson) F20TF10 in a coma
+ More Options
Posts
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    #61
    Re: RCA (Thomson) F20TF10 in a coma
    Fuse MP 50 can be repaired using a wire from the glass fuse of the same rating. Gently crush him, and to get the wire soldered to the conclusions of the burnt MP 50(wire soldered directly to the terminals closer to the body) pre-checked load resistance after the fuse in the circuit, which would not be short-circuited. 7809 test separately from the TV. Applied to the input (pin 1 and 2) 12-volt power supply and check the voltage at the output (pin 3 and 2)
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Thanks for the tips. I did meter the 7809 using diode function as well as restance and there's no short. I'll test it on 12v and see if it still functons. I haven't been able to find a 500mA 66volt fuse of any type though.
      • kasfamily
        • Aug 2014
        • 765
        • Russia
        #63
        Not necessarily put the fuse on the 66 volt, can be used on a larger voltage
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Thank you for the info. I was unsure about fuse voltage ratings but I have (re)educated myself about it.
          I tested the 7809 regulator and thankfully it works within tolerance; output is 8.86v with 11.78v input. Now to find a suitable fuse I'll keep you updated.
          • kasfamily
            • Aug 2014
            • 765
            • Russia
            #65
            Ok!
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Ok, I've got the 7809 back in (fastened with a nice screw into freshly drilled hole on the heatsink, to hell with that clip crap) and the fuse repaired and installed as directed. The fuse reads 1 ohm, same as before I took it out of the glass.
              So now I've got the 9v supply as well as the HV from the flyback. Should I try grounding the RGB CRT pins now with the screen up a bit like you said before?
              • kasfamily
                • Aug 2014
                • 765
                • Russia
                #67
                Well, TV is turned on, the screen is dimly-lit, mirror set, is used to test one wire end is connected permanently to the ground, (praying) briefly regard to the second end of wire to RGB pins CRT are alternately
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  No go. The screen control has no effect now, no dimly-lit screen, grounding the pins does nothing.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    The CRT heater measures 5 ohms but the votage across it has dropped to 6vac. The flyback is still putting out 27Kvdc but perhaps something internal of the flyback unit has faulted?
                    • kasfamily
                      • Aug 2014
                      • 765
                      • Russia
                      #70
                      Repeat 1-how many volts on pin 5 BU004 crt board. 2- how many volts to pin 2,3,4,6 BU003 crt board.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        BU004
                        5 = 188.8
                        BU003
                        2 = 1.2
                        3 = 1.2
                        4 = 1.2
                        6 = 8.7
                        Essecially unchanged from before.
                        • kasfamily
                          • Aug 2014
                          • 765
                          • Russia
                          #72
                          Measure the VG2 to CRT board and as the value changes when rotating the screen on flyback
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            VG2 = 75 to 534vdc from full ccw to full cw.
                            • kasfamily
                              • Aug 2014
                              • 765
                              • Russia
                              #74
                              may be a bad solder pin 4 on flyback
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Retouched that and also 5. I also cleaned up my repair where the 7809 is and double checked for shorts prper voltage, all good.
                                Now there is no CRT heater AC at all, heater still reads 5 ohms.
                                BTW, once again the front panel power button has zero effect on anything. I try pressing it and measuring everything again and it makes no difference.
                                • kasfamily
                                  • Aug 2014
                                  • 765
                                  • Russia
                                  #76
                                  Where are you measuring the resistance of the filament-heater directly on the CRT socket, with the removed board CRT ?
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    I measured the heater resistance both connected and disconnected from the circuit board. It is the same. 5 ohms.
                                    • kasfamily
                                      • Aug 2014
                                      • 765
                                      • Russia
                                      #78
                                      Π‘heck all connections and the rest of the fuses on the main board
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Already found another open MP 50 fuse near the 1st one, on the 7806 6v regulator pin 1 (input), which comes from the 7809 output BTW. Guess it's time to break open another .5A glass fuse.
                                        I'll pull the 7806 and test it too. At least it has a screw to the heatsink
                                        7806 is fine. 12v in, 6v out.
                                        • kasfamily
                                          • Aug 2014
                                          • 765
                                          • Russia
                                          #80
                                          Very well,expect to continue
                                          • edugimeno
                                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                            by edugimeno
                                            Hi!!
                                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                            At a certain point, moving stuff around, I put all wires back in place and...
                                            03-24-2024, 02:31 PM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                            Thomson NEO 15 WWN15I5-8BK1T Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO 15 WWN15I5-8BK1T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWN15I5-8BK1T boardview and WWN15I5-8BK1T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 06:21 AM
                                            Thomson NEO X14C WWX14C4BL64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4BL64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4BL64-P boardview and WWX14C4BL64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            Thomson NEO X14C WWX14C4PK64-P Notebook Specification for Upgrade or Repair
                                            This specification for the Thomson NEO X14C WWX14C4PK64-P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WWX14C4PK64-P boardview and WWX14C4PK64-P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
