RCA (Thomson) F20TF10 in a coma
Re: RCA (Thomson) F20TF10 in a coma
In the interest of time I did not repair this 2nd MP50 fuse but used a .5A glass fuse with leads for troubleshooting. After replacing fuse there is NO high voltage on the anode and I can hear HV hiss from somewhere.Comment
I can't see it in the dark but it sounds from the area of the 6v regulator, the hiss sound changes over a period of 1/2 second from quiet to louder quickly then down to quiet again.Comment
I did not forget, it is connected and confirmed good to mainbaord ground as well.
I checked with KV probe on connections in the area of 9 and 6 volt regulators (area where the hiss sound originates) with no results.
I pulled one leg for the fuse and got HV back on the CRT anode.Comment
The MP 50 below the fuse circled in the 2nd pic is the repaired fuse, the fuse wire I used from a glass fuse goes around the outside of the body on the right side. That checks ok.Comment
UB on mainboard has changed from 117.9v to 136.5v
CRT pins 11, 8 & 6 has changed from 177-180v to 102-105v
CRT anode has 0v
VG2 has 75 to 534vdc to 0.0v to 0.1v rotating screen control
BU004 pin 5 changed from 188.8v to 134.9v
BU003 pins changed:
2 was 1.2v now 0.3v
3 was 1.2v now 0.3v
4 was 1.2v now 0.3v
6 was 8.7v now 0v
Mainboard 12v, 9v & 6v test points are good.
I am thinking again it is some part in the flyback assembly.Comment
Pin 26 (IV01) is power a master oscillator flyback , it is necessary to check the resistance pin 26 on the ground. Trace the entire chain of the pin 26, there should be a zener diode and probably low-resistance breaking resistor from pin flybackComment
There is no conductivity from IV01 pin 26 to ground.
The zener checks ok out of circuit.
The resistor is 2.2 ohms out of circuit.
Traced to emitter of TP390, an NPN that tests good out of circuit. The base ties to 9VS2, which has tested good when powered.
That is as far as I've gotten so far.Last edited by SteveNielsen; 10-09-2014, 04:40 PM.Comment
Collector TP390 what is connected, you can see how the chain? I'm on a photo I can not check, fuzzy printing, may be even take a picture of this area from two sides. Principle of operation is that when the power is turned on the first 26 pin comes from the power supply, and when it begins to run flyback line scanning, the power to pin 26 comes with flybackComment
by madan1Hello everyone.
Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and... -
by sam_sam_samI recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
However I would like to know if I could figure what happened to this controller board if possible
Tomorrow I will take some better pictures of both side of both boards
The... -
by Jean4634Hi,
I'm looking for shematics for two devices :
1 ) Thomson Ampli preampli stereo PA 2517 T
2 ) Thomson tuner stereo T3017 T.
Thks
Jean-
by nopHi. I have an old Bosch/Powerstar AE125 water heater in my cabin whose control board died for the nth time. This time around, I figured I'd try to diagnose and repair it. At the end of the board's life its power indicator LED will quickly cycle on and off as water passes through the heater, rather than remaining steadily on as it normally would, and water at the tap remains cold. Slightly increasing pressure in the system by closing the outlet valve seems to delay the inevitable for a little while.
Here's all the info I found from Bosch regarding troubleshooting the board:
by sigmeyerFirst of all i just wanna say i love posting on this website and i get alot of useful feedback doing so , i just wish i could do it more often...
Okay , so i am currently doing nothing because of the corona outbreak thing and i was trying to repair a cheap toaster that i have...And unfortunately it is just as i thought , the heater is broken. And i was wondering what can i do about this? So here is what i tried so far
I have dissasembled an old chinese soldering iron and i took the heater wire from it to try reconnect the broken heater wire... and it worked untill the wire... - Loading...
