Re: Vizio E550VL: Plug In = continuous on/off clicking
I have not been able to find anything significant that I can tell is wrong on the main board. It remains incredibly difficult to test without being able to power on and measure voltages.
My theory is that there is a failed component somewhere in the 5vSB circuit causing a send or short to PS_ON, but also causing an autoprotect to trip and shutdown power, thus the continuous cycling, even with PS_ON cut.
Several questions:
1) When I test 5vSB, whether under (simulated) load or just the (digital) voltmeter, the tester jumps to 9.25v - EVERY TIME - for a split second before settling at about 5v. I thought it was just an anomalous reading before the voltmeter 'settled down,' but is this normal? Or is it a possible defect in the PS? Can I test by using a Computer PS to power the main board 5vSB with the LCD PS disconnected?
3) Can I cut 5vSB, and manually trip PS_ON to cut out 5vSB to the Main Board since that seems to be where the problem starts?
2) The Vizio E552VL uses the SAME LCD panel (LC550WUB-SCA1) as the E550VL. My Main Board has an integrated TCON (Chip in the upper-left corner of the board?). The inverter boards are listed as interchangeable for E550VL and E552VL. If I get a main board for an E552VL that has an integrated TCON chip...Will it work? It is much cheaper than getting the E550 VL Main board, if I can find one at all. I know I may have to remove an extra USB and HDMI port, or modify the case, but the mounting points and board size appear to all match up...
Thanks for any input!
Several questions:
