Vizio E550VL: Plug In = continuous on/off clicking
  • ulsh72
    • Apr 2014
    • 28
    Re: Vizio E550VL: Plug In = continuous on/off clicking
    I have not been able to find anything significant that I can tell is wrong on the main board. It remains incredibly difficult to test without being able to power on and measure voltages.
    My theory is that there is a failed component somewhere in the 5vSB circuit causing a send or short to PS_ON, but also causing an autoprotect to trip and shutdown power, thus the continuous cycling, even with PS_ON cut.
    Several questions:
    1) When I test 5vSB, whether under (simulated) load or just the (digital) voltmeter, the tester jumps to 9.25v - EVERY TIME - for a split second before settling at about 5v. I thought it was just an anomalous reading before the voltmeter 'settled down,' but is this normal? Or is it a possible defect in the PS? Can I test by using a Computer PS to power the main board 5vSB with the LCD PS disconnected?
    3) Can I cut 5vSB, and manually trip PS_ON to cut out 5vSB to the Main Board since that seems to be where the problem starts?
    2) The Vizio E552VL uses the SAME LCD panel (LC550WUB-SCA1) as the E550VL. My Main Board has an integrated TCON (Chip in the upper-left corner of the board?). The inverter boards are listed as interchangeable for E550VL and E552VL. If I get a main board for an E552VL that has an integrated TCON chip...Will it work? It is much cheaper than getting the E550 VL Main board, if I can find one at all. I know I may have to remove an extra USB and HDMI port, or modify the case, but the mounting points and board size appear to all match up...
    Thanks for any input!
      If the standby is power supply is not steady at 5V then the main board will not function, you can cut the ps_on so the main power supply will not be turn on (you do not need to have the rest of the power supply on for the main board to run, the main board should send out steady control signals out, the rest of the power supply that is turned on so you will have 12V for sound, and the PFC booster for the inverter circuits. Main board only needs that 5V to run. You can try external 5V power supply that can supply lots of current without going into shut down and then see which components will get hot or start smoking.
      "Can I cut 5vSB, and manually trip PS_ON to cut out 5vSB to the Main Board since that seems to be where the problem starts?" forcing the power supply on by applying the 5V through resistor to PS_ON and BL_ON turn on the rest of the power supply is fine, it will just proof that the PFC and the inverter are working. You already done that in post 5.
      • ulsh72
        • Apr 2014
        • 28
        I got to test the TV some more, and this time it magically stopped blinking on and off! I am getting standby power. When I press the power button, I get 1 click, and power to the TV. HOWEVER, (if I remember right, I don't have my notes in front of me) I still get the continuous blinking on/off when I press the power button if the 24v supply cables is plugged into the PS. I can get the main board into 'on' state I have them unplugged.
        MAIN POINT: After a minute or so, I smell something 'hot' and have to unplug the TV. I discovered that the HDMI chip is getting blistering hot while the TV is 'on.'
        Is the opinion still that the main board (or component on it) is likely bad?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          If i was in your situation i would look for a replacement main board it certainly sounds like the chip may be short circuit etc.
            A HDMI chip getting hot is a pretty common symptom of power surge damage entering through a HDMI cable, even if you did fix the other faults the HDMI ports would not work again. So I agree with Vince, I would look for a new main board.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              An alternate--seeing the other is MB Replacement--I wonder if the set would work if the HDMI Chip was removed,--as its obviously faulty anyway being it gets scorching hot...
              TELEFIX
              • ulsh72
                • Apr 2014
                • 28
                I was thinking that as well. However, I don't have a hot air gun. Just a soldering iron. Could I get it off without damaging the rest of the board?
                • ulsh72
                  • Apr 2014
                  • 28
                  Follow up question:
                  The Vizio E552VL (LATPKIBM) uses the SAME LCD panel (LC550WUB-SCA1) as my Vizio E550VL (LASPHCAL)(source). My Main Board has an integrated TCON. Also, the inverter boards are listed as interchangeable for E550VL and E552VL. If I get a main board for an E552VL model that uses the same panel and that has an integrated TCON chip...Will it work? It might be much cheaper than getting the E550VL main board, if I can find one at all. I know I may have to remove an extra USB and HDMI port, or modify the case, but the mounting points and board size appear to all match up...
                  It also looks like the E551VL (LASPHCHM, LASPHCHL) main board would substitute as well? (source)
                  My findings are all these should work...ANY OPINIONS OR ADVICE??
                  ORIGINAL Vizio E550VL (LASPHCAL):
                  PANEL:LC550WUB-SCA1
                  MAin Board:
                  3655-0152-0150 (4G)
                  CSD: 3655-0152-0395
                  E550VL Replacement:
                  3655-0072-0395R
                  3655-0072-0150
                  Alternate E552VL (LATPKIBM):
                  3655-0352-0395R
                  3655-0352-0150
                  Alternate E551VL (LASPHCHM, LASPHCHL)
                  3655-0332-0395R
                  3655-0332-0150
                  • ulsh72
                    • Apr 2014
                    • 28
                    I am happy to report that this DOES work and I got the TV functioning normally!
                    I was able to use a 3655-0352-0150 from a Vizio E552vl in a Vizio E550VL that uses LCD panel LC550WUB-SCA1.
                    All functions work, all inputs, digital and analog work! All I had to do was dremel holes for the extra ports on the back cover. I was able to pick up the board for $90, instead of the original replacement priced at $170. I also gained an extra USB port, and wireless (net yet tested) and wired connectivity and apps!
                    Thank you to all who assisted me!
                    Originally posted by ulsh72
                    Follow up question:
                    PANEL:LC550WUB-SCA1
                    MAin Board:
                    3655-0152-0150 (4G)
                    CSD: 3655-0152-0395
                    E550VL Replacement:
                    3655-0072-0395R
                    3655-0072-0150
                    3655-0352-0395R
                    3655-0352-0150
                    3655-0332-0395R
                    3655-0332-0150
                    • bffargo
                      2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                      by bffargo
                      LG 60PB66550 NOV 2014
                      PSU: EAY63168603
                      PCB: EAX65359531 2013.11.01 Rev:1.0
                      Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                      Symptom:
                      While watching, just went black and started clicking relay every few seconds.
                      Initial diagnosis:
                      Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                      Deeper diagnosis:
                      Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                      09-09-2022, 07:34 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • gavric
                      Vizio M70-C3 Half picture is bad, main board on its last leg?
                      by gavric
                      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                      When tv powers on vizio V logo shows nice on whole screen. picture 1
                      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                      When i click video to start playing picture goes black(like when you change...
                      09-02-2021, 08:55 PM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      07-14-2025, 07:28 PM
