vizio m220mv red snow
  • MiaaZ
    • Sep 2014
    • 24
    vizio m220mv 2009 and uses a power brick to plug in. I have not found much info on this tv, except reviews.
    In this first pic you can see the red snow only in a portion of the screen, I believe it was in standard 4:3 mode, so the portion that was not getting a video signal seemed not to show this effect. (If my thinking is correct)
    Second pic is the LVDS portion of the mainboard where I replaced the on 470uf cap and re-flowed the 22uf 16v caps. The 22uf caps I have are half the size of the origonals, so I did not replace those yet.
    Visually all the caps look ok, the boards had what appeared to be some white oxidation on the board and some of the solder joints.
    I replace a few of the 470uf 16v and 470uf 25v caps by the points where voltage was coming into the board. Some of the red snow went away. Opened it back up and re-flowed quit a few of the joints mainly the caps and connecters for shits and giggles. The ones that I did replace had air pockets under the solder joints and did not flow well at all. Slapped it back together and all the red snow was gone, picture looked beuitiful, UNTIL it ran for about an hour my friends RV. Where he had the heater going. I had tested it in our cool basement and it ran fine.
    It only has 2 boards, the main board, and power board, well and the one across the top of the lcd. The power brick I was able to get open somewhat to peak at the caps and they looked ok also, so I didn't tear it apart any further. I didn't test any voltages cause quit frankly I have no clue what they should be, and the mounting of the boards make it near impossible.
    I have seen alot of posts that say to change the LVDS cable, but after doing so the symptoms return anyway. reseating helps again for awhile.
    Any thoughts on this issue and an area to concentrate on?
    thanks
  • MiaaZ
    • Sep 2014
    • 24
    Re: vizio m220mv red snow
    And here is the power board. I have a few more of the main board, just trying to get them resized.
    • 1beertap
      • Mar 2009
      • 219
      It sounds like you probably have bad or failing TCON board.
      • MiaaZ
        • Sep 2014
        • 24
        22" Razor Class LED-LCD 1080p 60Hz HDTV , 1.75" ultra-slim M220MV
        This model does not show a TCON board on vizio's parts list, so I think it is built into the main board. The only other board really is where the 12v plugs into the powerboard.
        Which part of the mainboard covers the TCON functions?
        These four pics make up the main board.
        • mmartell
          • Oct 2013
          • 3189
          Where does the cable at the bottom of pic 1 go ? A shot of the back of the set would help us to know the board layout.
          • MiaaZ
            • Sep 2014
            • 24
            It goes to the board that connects at the top of the screen with 6-7 flat copper colored ribbon type connections.
            under that metal cover is two more flat white ribbon cables that go from the power board and seem to just connect right into the LCD panel, one at each end of the LCD screen. (black tape on far left top and bottom)
            And the cable that is not attached in this pic #3 goes to the power board.
            Do these help or do i need to get more pics?
            • mmartell
              • Oct 2013
              • 3189
              Well that would normally be your tcon. Is it removeable ?
              Wires from the power supply running directly into the panel are usually driving led's so I would guess that's what's going on there.
              • MiaaZ
                • Sep 2014
                • 24
                No, it is not from what I can see, looks like it is attached to the screen itself some where.
                  Unplug and reseat that cable going to the "T-con". Do both ends.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Give it a brush with isopropyl alcohol while you're at it.
                    A working TV? How boring!
                    • MiaaZ
                      • Sep 2014
                      • 24
                      I did that the last time, with the alcohol too, but that was also at the same time I re-flowed some of the solder joints on those main board connections, just not every last one.
                      And also where the end connects into the board attached to the screen, I pressed the thin metal down onto the connector a little. The other end is a real bear to go on, really requires some preassure.
                      When I get the TV back later today, I'll do all three again independently to see which had the positive effect on the picture. (If it does again )
                      While wiggling that cable itself did not change the picture at all, for good or bad. (no tape over connection holding it still)
                      Neither did squeezing/tapping the panel connections where the ribbon cable goes into the panel itself.
                      I also tested continuity on the wires all seemed good with the same readings on all of them.
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • mrtek
                        Vizio M65-C1
                        by mrtek
                        Hi.
                        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                        07-14-2025, 07:28 PM
                      • howardc64
                        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                        by howardc64
                        Failure Symptom
                        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                        Where is the short?
                        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                        05-27-2025, 02:56 PM
                      • howardc64
                        Vizio SmartCast TV software bug that looks like hardware
                        by howardc64
                        Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                        It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                        11-16-2024, 05:17 PM
