Purchased bad TV to repair but it works
  • bowtie20
    • Mar 2014
    • 10
    I know this is a very broad question but I just bought my second (won't power on) TV and when I bring it home it works just fine. I just want opinions from some folks with more experience than I have with TV repair because this is bound to be a common occurrence. And yes I'm pretty confident they aren't stolen. The first one was a 47" LCD Toshiba. I watched it for about a month just to make sure it wasn't an intermittent fault before I resold it. The second is a 32" LCD Sylvania I just purchased. Both sellers claimed symptoms typical of a bad power supply. One even claimed they had a surge that "fried" the TV. My thoughts are after the TV is unplugged for so long maybe it comes out of some kind of "protect" mode. Any suggestions on how to handle these would be greatly appreciated because I'd hate to sell someone a TV that's just waiting to go out again.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Purchased bad TV to repair but it works
    all TVs have a protect mode, or seven, but they should reset after a power disconnect. if the OO (original owner) didn't disconnect and reconnect power, then yes, it could be a protect mode. else i would bet the farm that you can find at least on bad solder joint that was shifted back into making a connection when the TV was moved.
    Follow the white rabbit.
    • mmartell
      • Oct 2013
      • 3189
      Since you posted this twice I will reply twice lol.
      Agree with goontron. I would take a hair dryer/cooling spray to the boards one at a time to try and induce the fault the owners were complaining about.
      • johnboy1313
        • Nov 2012
        • 1959
        I was just given a 58" Pannasonic TH-58PZ700U that was "fried by lightning". I got it home, plugged it in, and it came right on. I haven't touched it since. It weighs 165 lbs and is a little more than I feel like moving around by myself.
        • bwilliams60
          • Aug 2014
          • 109
          Just curious, why are you buying bad TV's? You can go to electronics recyclers and swing a deal with them and get them all day long for free. Maybe throw them back a good repaired one that you have that didn't cost much to fix just to keep them happy. No point buying them. Broke is broke and should be free. Paying for them makes you broke.
          • johnboy1313
            • Nov 2012
            • 1959
            The only electronics recycler around here is an hour away and they fix what they can and sell them. No freebies coming from that place. The only way I can find them is through Craigslist or people I know.
            • bwilliams60
              • Aug 2014
              • 109
              Do you have a Habitat for Humanity around your area? We also have guys that go around and pick up scrap steel (and anything else that isn't tied down) and usually they will pick them up.
              • Hobby 1
                • Mar 2010
                • 86
                I've bought sets that work when I try them at home. I don't try them at the seller's place unless they have it ready and plugged it. I've had them back out if the set starts to work properly again. At my home, I open them up and see if I can spot any damaged parts like caps, etc. If nothing bad is found, I use the set till it fails which can be from a few hours to as long as 6 months before the stated problem shows up. Then I fix it.
                The problem with sets from recyclers is if they are even willing to give/sell them is that they get pretty badly scratched up because they are treated as broken/scrap.
                • bwilliams60
                  • Aug 2014
                  • 109
                  And sometimes you just get lucky. I just picked up a 55" Toshiba LCD with a bad TCON board. Should see it next week and hopefully that's all that's wrong. Beautiful TV though, excellent shape. There are tons of TV's being recycled for simple repairs. No different than bicycles and anything else that society feels is not repairable.
                  • bowtie20
                    • Mar 2014
                    • 10
                    Thanks everyone for all the feedback. Unfortunately I'm not aware of any recyclers in my area but I am in the process of working out a deal with the trash pickup people. They actually came to me when they saw the tvs with the broken screens I sell the boards out of on the road. When I do purchase them to repair I rarely pay more than $30 and still come out with a pretty good profit, especially if I can repair it at the component level. Sellers basically have the option of something or nothing for them so they will sell for cheap. And again sorry for the double post, when I realized there was a better place to post this I reposted and intended to delete the origional but tried about a half hour and couldn't figure out how. This is literally the second thread I've started in my life. Or third if you consider the double post.
                    • CapLeaker
                      Dell ATX PSU won’t start, but forcing it works fine?
                      by CapLeaker
                      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                      10-28-2024, 06:59 PM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                      🛠 Original Issue
                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ex250
                      Kenwood SW-505D no sound issue and pops from time to time when it works
                      by ex250
                      Hello mates,
                      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                      12-29-2024, 03:27 PM
                    • eurowill
                      a2141 820-01700 internal display not working / external works
                      by eurowill
                      Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                      Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                      07-23-2024, 10:06 AM
                    • vf fa
                      EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                      by vf fa
                      Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                      I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                      So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                      01-31-2024, 01:40 PM
