Panasonic TC-P42C2 6 blinks
    Getting a 6 blink error code.
    Replaced sn board. Green led is dim gets bright then disappears.
    Do I have to replace ss board with the sn?
    Re: Panasonic TC-P42C2 6 blinks
    What blink code now? Do a check on SS11 and see if shorted or check all the RJP30E4 transistors for shorts. Normally I think with them bad you'd get 10 or 4 blink.
    Always a chance you received a dud SN board.
      6 blinks.
      well i bought an ss board originally but that didnt fix the tv so then i ordered a sn board and had the tv working.
      but i then put in my old ss to test it and i think it took out the new sn. i was just trying to see if the old ss was even bad. now it wont work after putting new ss board back in.
      shop jimmy sent a replacement sn board. still no luck so im thinking maybe i need to get a new ss as well again.
      how do i check for shorts?
        yeah, that's a bummer. The old saying of leave sleeping dogs lay.
        Good chance that's what happened.
        I did something similar this week. repaired SS blew out those RJP30E4 transistors again and did not fully disconnect it from the SN, just ss11(vsus) which was short but the other connector that feeds back to the SN was also short and bang, dead SN.
        Grab a meter and set to diode or continuity mode and either pick any 2 legs on those transistors or gnd and Vsus at SS11.
        You could be going around in circles here. Test both boards. on the sn some transistors that commonly short are q661,401,402,421,451,441.
        post what you find
        constant beep or low/zero reading would indicate short
          Hi all:
          Hope this thread will be of help to me an others
          I am a newbie... Just wanted to say hi and H E L P ! I have a strange problem with a Panasonic tc-p42c2 It shown 6 blinks after it warmed up (35 - 40 min) and then it will not show image again until it cools. Took the back off and checked for bulging caps. Nothing. Tightened all fasteners and powered on. Perfect. kept it on for over 2 hrs and no shutdown. Put the back on and now it won't even show a picture when cold. Will post in the right area...
          Capacity
            Originally posted by Capacity View Post
            Hi all:
            Capacity
            That sounds like an A board problem more than anything else. Before the TV used to shut down, did you ever notice any "flutter" in the picture, for example dead pixels, pink/purple/white discolouration, flickers on the screen, etc? Or would it be picture perfect then bang, shut down?
              yes... it did flutter and tweak out a bit before the picture went out. When I had the back off it worked great though. Now I cant even get a picture at all... Just the 6 blinks
              Thanks for the help
              Is there a way to test this component?
              CAPacity
                There are some LEDs on the SC and SS, do these light up at all?
                Do you have a digital multimeter, and can you use it?
                  Yes .. I have a nice Fluke and have put it through its paces on numerous occasions. The values and locations to probe are unknown. I have looked for an A board at Jimmy and they are out of stock. Could I rebuild it? Or send it in for a refurb? I could search for a service manual online I guess. I am sure it would have a walk through with step by step diagnosis. If anyone has the inside scoop..please let me know :~}
                  Capacity
                    still dead ended on this...so much time. anyone know about all the revisions for the A boards on these?
                      just a quick one the boards are used in both HD and FHD sets, FHD boards will not suit, from there it's size specific but other 42" HD boards will work but have varying features
                        I'm going with A board, I did a U20 which had no picture but turned on. replaced it with another board i had laying around but never used and it too was faulty with picture but flickers red and blue bars.
                        Third board fixed it. these boards get very hot especially the bga . My v20 it runs really hot too which is not great. i'd say that chip the solder breaks free as an assumption.
                        HD TV versions
                        TNPH0831AR 42PX24
                        TNPH0831AT 42C2
                        TNPH0831AU 46C2
                        TNPH0831AV 50C2
                        Not suitable FHD boards
                        TNPH0831 42S2
                        TNPH0831AB 46S2
                        TNPH0831AC 50S2,
                        TNPH0831AD 54S2
                        TNPH0831AE 58S2
                        TNPH0831AF 65S2
                        TNPH0831AG 42U2
                        TNPH0831AJ 50U2
                        if you get desparate you can convert a 46" or 50" by either doing an eeprom swap or if you have the gear copy the data from your eeeproms and overwrite the equivalent chip on the other board.
                        i've only done IC swaps but I am going to try an eeprom writer out if i get the chance so it's less intrusive.
                        If you choose the later path touch base so i can double check what chips need to be swapped
                          Bingo. Craigs yielded a few faulty sets. Some quick board swaps and the image has never been better. I now have two working panny 42"s and a stack of known good and known bad parts.
                          Funny, it feels so good to get a 5yo beater set back on its feet.
                          Thanks TW2005
                          Cap
