LE40R87BD restarting after 10 seconds
  • fruitbat04
    • May 2014
    • 50
    Hi there,
    I have the above TV with a IP231135A power board. The symptoms are that it powers on for about 10 seconds, the relay clicks back off and it restarts.
    The capacitors all look OK and the voltages on the rails are as expected.
    Can anyone advise on the next step?
    thanks
    Re: LE40R87BD restarting after 10 seconds
    Likely a main board issue.
    • fruitbat04
      • May 2014
      • 50
      I should have specified, in the brief time it's powered on, you can change channels, get into the menus etc.
      Would that still point to a main board issue?
        Yes, it has been seen before on this model. Sometimes you will also see graphical glitches on the screen. You might want to try turning off the READY mode in the service menu, sometimes that can help.
        • fruitbat04
          • May 2014
          • 50
          Thanks Tom. I am seeing graphical problems as well.
          After having it completely dissembled and reassembled it does seem better, although I'm sure it's not a permanent fix. I did a factory reset from the service menu however both before and after, READY was already disabled. Could you please explain what that setting is?
          thanks
            Some people have had luck reflowing the processor on these boards.
            I am not sure what READY does but setting it on usually causes the TV to reboot every few minutes.
            • fruitbat04
              • May 2014
              • 50
              Had a google and if you have READY on, it disables the DTV and Analogue, so I would have thought being off would have to be the default option.
              It wouldn't surprise me if it was something like that on the main board. Basically this TV is an office one on 24/7. After I put it all back together and powered on from cold, it restarted twice and then seemed OK. On the first power on, there was corruption as you describe which then got better. I wouldn't expect this to last all that long, and if it goes again, I'll try a reflow.
              • adamp91gvm
                • Jan 2014
                • 699
                I had a problem like this I reset the eprom on the av board and it worked fine
                • matyka
                  • Jan 2015
                  • 179
                  • Uk
                  Hello I have the same problem on my le40r87bd.
                  After I changed all the bad capacitors and reset the ic eeprom and after changed the eeprom with a new one I have the same graphical problem
                  Tv starts first time with graphical glitches see photo and about 2 -3 restarting the picture is getting better and after 2 min is perfectly fine.
                  Is this mean is the main board faulty any idea ?
                  • stevespeed26
                    • Dec 2017
                    Hello All, I have this same problem on a LE40R88BD, did anyone find a way to resolve this issue with the Graphical Glitches from the Main Board after Replacing Bad Caps on the power supply?
                    • lawrenceptrini
                      Lenovo Ideapad 100-15ibd restarts every few seconds continuously.
                      by lawrenceptrini
                      Laptop turns on and restarts every 7 seconds or so.
                      Power led and Webcam led turn on and goes off repeatedly.
                      Pressing the power button does absolutely nothing.
                      Same thing happens whether the bios battery is connected or not.
                      I tried resetting the bios, press power button to drain power etc.,
                      but no change same thing. I tried numerous ram modules but same result.
                      Using a desktop power supply I can see the amps going to zero and rebuilding,
                      same thing with multimeter. Doesn't matter if I plug in adapter or main battery,...
                      12-27-2024, 10:20 PM
                    • PACh
                      MBA A1932 820-01521-A no Post after few seconds it restarts
                      by PACh
                      Hi, I need help fixing this. Any help will be highly appreciated.
                      Got a macbook air A1932 820-01521-A with the trackpad click not working, the fuse was blown (its never the fuse) I tested the line and seems ok, replaced the fuse and it worked again... all good BUT when I tried to remove the board again I pressed the reset switch (SW6955) next to the battery connector WITH the USB-C power still connected to the board.... I pressed and kept pressed for some seconds twice because the fan started to spin... then I realized why.... 😕
                      After that the machine wont...
                      09-17-2022, 07:34 AM
                    • zklgfs
                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                      by zklgfs
                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                      08-11-2025, 02:14 PM
                    • twonk9098
                      Lenovo Legion 5 high fan spin turns off after 34 seconds
                      by twonk9098
                      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                      I have tried a few new bios but exactly...
                      07-14-2024, 11:19 AM
                    • Stephen
                      MacBook Pro 14" M1 Pro Issue (Works but issues)
                      by Stephen
                      No water damage, customer brought in MacBook Pro 14" A2442 M1 Pro. No water damage present, could not restore the machine but finally got it to restore after multiple attempts. Now the computer installed OS and it is activated. It now restarts and restarts every 3-10 seconds CONSTANTLY. Again no visible water damage, took the board out to inspect and still no signs of damage. Mint condition looking laptop. Computer turns on yes and has Sonoma, however JUST keeps restarting, no crash reports nothing, just KEEPS restarting every 3 seconds, sometimes it was instant back to back like 1 second...
                      11-07-2023, 02:38 PM
