Sony XBR-75X940E intermittent 6 blinks error code
  • GoodCapDude
    • Sep 2025
    • 8
    • France
    Hi everyone. First post on Badcaps!
    I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot.
  • EazyBone
    • Jun 2023
    • 1352
    • United states
    Bl error. It can be that power board above the main one which went bad, it could be led driver, could be bad LEDs. Shorting the pin would probably tell if it's the LEDs are bad if it'll start and you can go to YouTube and do a screen test and see if one of the LEDs is bad.
    If LEDs is bad then shorting the pin is the only way beside changing them as far as I know
    • Diah
      • Feb 2013
      • 6425
      you have crack soldering point at PSU
        • 12241
        • U.S.
        Check the soldering as suggested, could be a backlight, suppose it could also possibly be a marginal/bad electrolytic capacitor on one of those boards. The hairdryer trick (just heating the electrolytic caps for a minute or two and trying the tv before they cool off) sometimes works to sniff out a marginal/bad capacitor.
        • GoodCapDude
          • Sep 2025
          • 8
          • France
          Thank you for your reply Diah. I'm not very skilled, I removed one of the three boards forming the PSU (G6, the other two are G75 and G78), I looked at soldiering points but there is little I can identify by just looking, right? Or is a "cracked soldering point" visible to the untrained eye? It's frustrating to think that this set could be back to life with just some solder at the the right spot!
          • GoodCapDude
            • Sep 2025
            • 8
            • France
            Thank you for your reply EazyBone. The leds seem fine when the TV start normally. The problem is that now that it is facing down, I have no access to what's on the screen. I'd rather not move it as it weighs a ton. I can still see the white led at startup, the red led blinking 6 times or whether the panel is normally lit.
            • GoodCapDude
              • Sep 2025
              • 8
              • France
              Thank you for your reply nomoresonys. Your name is thought provoking! 😂 I'm not sure about the hairdryer because those capacitors are so close to each other that I'm not sure I can heat one in particular. Also, since the TV does start normally from time to time, it'll be hard to tell if it's whether I heated up the capacitor. Maybe I should buy a multimeter to test every capacitor? I've seen some device allow testing components without removing them from the board. I really like this TV but maybe the most efficient way to go is trying to short the BL_ERR and just see how much life it still has in it?
                • 12241
                • U.S.
                Sure you can try it, if you look closely at how the wire is in the connector you can remove it without having to cut or damage the wire then ground it. That way you can just slip it back on if it's not the problem. At least a lot of them are configured in that manner, I use a really small screwdriver to unlatch it.
                  • 12241
                  • U.S.
                  Bad solder joints can be easy to spot or tricky, I would add a little to any that look even a little suspect, just be careful not to bridge anything that shouldn't be. Also don't want to get any globs that could result in a bad joint. Pay attention to transformer joints and anything on a heatsink. They work hard and usually crack first. Examples of bad joints there: https://www.google.com/search?client...&bih=671&dpr=1
                  • GoodCapDude
                    • Sep 2025
                    • 8
                    • France
                    Thanks for the link. I think I have a clearer view of what a bad joint is. I have checked all 3 boards and did not find anything that really stood out. My confidence level in my assessment is quite low obviously. Also I think it has to be subtle since it works from time to time, right? So I put everything back together and the TV started. But then I turned it off and on and I had the 6 red blinks again. So I'm back to square one.
                    Thankfully, I can keep the TV opened a few more days but it looks like I'm going eventually to have to ground BL_ERR and throw it away if it does not work. And maybe put it on the wall if it works. But then I may realize that by bypassing the error code, I find a significant backlight problem. There is no way I can investigate the led strips with this beast, it is too massive. I could never put it back together.
                    Thanks for your help in any case!
                    • tiki66
                      • Jul 2016
                      • 49
                      • Croatia
                      Maybe a segment of LED's won't turn on when they are cold so tv goes into backlight error. But usually when there is something with these tv's and backlight it goes into 4x error, not 6x...
                      Anyway, try grounding BL_ERR and it could solve your problems. It is pin #27 on CN1001 on LD board that you have to ground (that small flat cable that goes from MB to LD board)
                        • 12241
                        • U.S.
                        Sonys are notorious for this kind of fault, that is starts sometimes but mostly will get the 6 blink code. Doesn't have to be but I think mostly it's related to a faulty backlight led that works only when it feels like it.
                          • 12241
                          • U.S.
                          Guess it could be a connection problem, maybe give that single cable going from powerboard to ld/backlight board a little wiggle just to try to make sure none of the wires are broken or only getting intermittent contact and take that cable off and check for burn or discoloration on each end. I use stripped bread ties inserted in the ends of the cable to check each wire for continuity with multimeter.
                          • GoodCapDude
                            • Sep 2025
                            • 8
                            • France
                            Thank you nomoresonys and everybody. I may have found a "cold solder" in at least one these four identical components (first pic). The culprit would be in the close-up pic. Could this explain an erratic start behavior of the TV?Click image for larger version
ID:	3730041 Click image for larger version
Name:	WhatsApp Image 2025-09-22 at 01.11.26.jpg
                              • 12241
                              • U.S.
                              Sure go ahead and add some solder so it looks like the rest and try it.
                              • Curtissimo
                                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                by Curtissimo
                                Hi everyone.
                                I have a HP Elitebook 850 G8.
                                Serial: 5CG2324XM0
                                ProdID 6L8D5EC#ABA
                                It has a Winbond W25Q256JVEN Chip.
                                I need to remove BIOS Password.
                                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                Attached my dump.
                                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                What I did:...
                                08-26-2025, 04:42 AM
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                              • AK_777
                                Sony KD-65A1 Repair – 4 Red Blinks Error
                                by AK_777
                                Hi everyone!
                                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                02-20-2025, 04:15 PM
                              • jchon
                                Sony A1e 5-blinks help
                                by jchon
                                Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                I found the service manual, which was critical to know where to probe.
                                https://www.manualslib.com/manual/20...1e-Series.html
                                With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                Unfortunately the 5-blinks...
                                06-28-2023, 11:52 AM
                              • dumbdd
                                Sony 75X9400E TV.. 5 Red blinks
                                by dumbdd
                                I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
                                When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
                                The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
                                07-01-2023, 08:54 PM
