vizio gv42l dead please help
    Re: vizio gv42l dead please help
    Those on my link are what I stock for repair, I order enough so make it worth the shipping charge. It will be good idea to have all of them if you do plan to work on more Vizio TV. It is up to you.
    • j0gigs
      • Dec 2012
      • 56
      Budm,
      If I were to order all the regulators, can you help me to make sure I order the correct ones?
      u6, abf601, ?
      u4, abf601, ?
      u8, abf601, ?
      u5, amc1117 / f0615j, = adjustable
      u10, 6e5l / 17-18l = 1.8v fixed
      u9, 6e5l / 17-18L, = 1.8v fixed
      u7, 6e5l / 17-18L, = 1.8v fixed
      u16, 6e5l / 17-18L, = 1.8v fixed
      Du2, abf601, = ?
      du3, 6d1l / 17-25L, = 1.8v fixed
      du4, amc1117 / f0615j, = adjustable
      du1, 7805ct / rjn539g, in = ?
      I am not sure what the abf601 regulators or the 7805ct regulator is.
      I'd rather order them all just in case the u5 is not the only bad one. The regulators are cheap enough. It's the shipping that's expensive.
      • j0gigs
        • Dec 2012
        • 56
        Budm,
        Thanks for all your help. U5 fixed it.
          Great news!
          Can you please post the readings of all the regulators again so it will help other people with the same problem and same board as you have?
          • j0gigs
            • Dec 2012
            • 56
            I put the tv back together. I will have to get some time to take it apart again.
            • j13
              • Oct 2015
              I have a Vizio GV42L and have tested all the regulators and my DU4 regulator is an AMC1117- F0646J and it tested at In=3.3v Out=0.62v grnd = 0.00. All others tested much higher on the out. Would you suspect that this regulator is bad?
              Thanks,
                That is not right, the minimum output will be 1.25V. Check the resistance between the output pin and Gnd to make sure it is not the load that is causing the output to be low, but more likely to be bad reg.
                • zape
                  • Jul 2017
                  • 176
                  Sorry to bump this old thread.
                  I came around this TV and found out that PSU wont turn on. I only get 5v stand-by.
                  I checked the transformer and it appears to have damaged primary coil (and no connectivity) see photo attached
                  I guess there is no way to fix this
                  So my question is: My PSU has part number 0500-0507-0410. Can it be replaced with P/N 0500-0507-0331 (which looks the same but much cheaper on ebay)?
                    Did you verify if you do have the >2V at PS-ON pin to turn on the rest of the power supply on?
                    I doubt that you have open winding for that transformer, look at the size of the wires.
                    Show us where you tested the transformer pins.
                    http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
                    • zape
                      • Jul 2017
                      • 176
                      No I did not verify the PS-on
                      There is no connectivity between pins 6 and 4 (same with 6 and 1, but 1-4 is OK), photo attached
                        Primary has only winding between pin 1 and 4, it is driven by half-bridge circuit, pin 1 is connected to the DC BLOCKER/COUPLING cap to GND, Pin 4 is connected to the center connection of the two power MOSFETs. The upper part of the bridge is Q601, the lower part of the bridge is Q602. The PFC Boosted Voltage is fed to the Drain pin of Q601 through fusible resistors R805, 806 which are connected in parallel. the Source pin of Q602 is connected to GND. Pin 6 is not used, it just a blank pin, it is used to supporting the transformer to the circuit board, common practice, That transformer form factor can be used to make many versions of the transformer I.E. one may required to have primary winding with center tap so all 3 pins will be needed.
                        If there is no PS-ON the PFC Voltage booster will not be on and you will not get the circuit that drive the transformer to function to get the 12V and the 24V output. I would check and see if you have PS-ON or not and if you do then the DCV between the two legs of the main filter cap (big cap with 450VDC rating) should be 380~400Vdc due to PFC is now turned on because of the PS-ON is present.
                        So check to see if PS-ON is present or not, if not then more likely you have bad regulator IC/IC's on the main board. Also check all the fuses on the main board.
                        May be you should read this: https://www.badcaps.net/forum/showthread.php?t=25810
                        Learning about half-bridge transformer driver:
                        https://cdn.badcaps-static.com/pdfs/...99120f3b33.pdf
                        LLC-HB topology
                        • zape
                          • Jul 2017
                          • 176
                          PS-ON is 0v
                          Two 3A Fuses on the Main board are good. How do I check the regulator IC/IC's on the main board?
                          Not sure if this helps but shortly after powering up I hear some relay click on the PSU and big cap voltage is 160V. Visio logo lights up.
                          If I disconnect the main board from the PSU I hear no relay click but the big cap still reads 160v.
                            Read reply post #3 of this thread "vizio gv42l dead please help". See how OP report the readings in format that is easy for us to understand.
                            Also read this one:
                            https://www.badcaps.net/forum/showth...999#post300999
                            • zape
                              • Jul 2017
                              • 176
                              here is some readings from the ICs:
                              Chip, Part#, ADJ pin, Out pin, In
                              U7 AMC1117 0 0 0
                              U9 K1117S15 0 0 0
                              U33 AMC1117 0 0 0.02
                              U8 AMC1117 2.06 3.31 5.18
                              U2 AMC1117 0.04 0.06 0.02
                              Diodes and transistors around seem to be good
                                Too many missing Voltages feeding the input pins.
                                If you look at U8 which has an output of 3.3V, as you can see, the output pin (big tab/center pin) is connected to very small inductor L12; check and se if you are getting 3.3Vat both ends of that inductor or not, also see if another end of that inductor goes to, it should go to the input pin of one or more of other 1117 regulator ICs.
                                • zape
                                  • Jul 2017
                                  • 176
                                  L12 is good, looking at the traces I think this IC is only used to drive the PS-ON PSU signal.
                                  Trying to find out how other ICs are supposed to be fed.
                                  Any chance to get a schematics diagram of this board?
                                  • zape
                                    • Jul 2017
                                    • 176
                                    OK I figured out that U7 and U9 are fed by U33
                                    U33 and U2 are fed by another IC U1 (4953gm) which is basically a Power mosfet
                                    U1 source is fed by +5vsb (reads 5.18v)
                                    The gate pin of the U1 reads 4.79v
                                    The conclusion is U1 is dead.
                                    The question is: can I just short the source and the drain pins of the U1 just to test if TV will turn on?
                                      Since U1 is the P-CH MOSFET (Souce pin is fed by b+), that means the Gate Voltage has to be 2~4V below the Source Voltage for the U1 to be biased on. You can force on that U1 by grounding the Gate pin via 100 Ohms resistor.
                                      You should find out what the Gate pin is connected to so you know what is driving the Gate pin.
                                      • zape
                                        • Jul 2017
                                        • 176
                                        looks like the control goes from the BGA chip.
                                        Here is a diagram with some voltage readings
                                        • zape
                                          • Jul 2017
                                          • 176
                                          So I tried to ground the base of the Q3 and it turned the U1 on and eventually powered up the other ICs. So this part appears to be working as designed.
                                          It did not turn on the PS-ON though.
                                          Any ideas?
                                          • k370
                                            Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                            by k370
                                            I have a NM-A321 board that is dead, with no power at all.
                                            When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                            With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                            • +3VALW
                                            • +5VAUX
                                            • 1.2VSUS_PWRGD
                                            • 3VALW_PGD
                                            • 1.05VAUX_PWRGD
                                            Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                            The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                            09-23-2024, 11:57 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead: PSU or Main Board?
                                            by fharris1977
                                            Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                            03-12-2024, 12:22 PM
                                          • corrize
                                            Nikon D5 – dead, power board issue ?
                                            by corrize
                                            Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                            When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                            I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                            Now, I try to understand how it works.
                                            There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                            04-03-2023, 09:13 AM
