Sony KD-65XE8596 no standby light
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4498
    • Italy - Milan
    The whole discussion started wrong, i suggest to re test all by the begin, some measurements, the pin numbers, and the rest doesn't match, first gather a proper piece of straight wire to be instert in the connector, test all pins, if no volts, the check the main 400v cylinder caps, stay concentrated, a wrong move can make an huge spark, if you have no steady hands, don't try , then search for fuses..
    • tiki66
      • Jul 2016
      • 57
      • Croatia
      Originally posted by brithepi2k
      Pin 2 main board : 2.63v
      Pin 7 main board : 12.83v
      Pin 10 main board: 12.84v
      Pin 11 main board: 2.58v
      Then it's probably a main board issue, not PSU
      • brithepi2k
        • Dec 2024
        • 19
        • Scotland
        Bought a new Power board, still got the same issue… seems like it’s the main board
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4498
          • Italy - Milan
          If you think you want to buy every part without thinking and no measurements so theres no need to open a thread, it's only a pain to read for a tech..
          • brithepi2k
            • Dec 2024
            • 19
            • Scotland
            There was also an issue with the power board, it’s a new power board so now it’s just a case of knowing what I can check next in order to possibly fix the tv, still getting no standby light. So let’s start fresh. Power board is 100% working, now I need to know what else to check. No more parts are being bought. Thanks and much appreciated
            • zomi
              • Nov 2011
              • 510
              #26
              I woudl suggest trying with wifi card disconected.. if still no luck
              You have a bad emmc, u will need a new mainboard ..
              thats the most likely cuprit.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • FMstatic
                Sony KDL-48W657D (main board protect, green light steady at the same time red light s
                by FMstatic
                Diagnose (panel problem)
                - main board replaced- still no good
                - panel board check all supply present and correct voltage
                - hang flex ribbon main board to panel (error 5blink) but when connected again nonstop red blink no pose and green light steady
                -SDA and SCL supply 3.3v panel board
                -BL is good simulated
                Guys help me any suggestion
                Main board protect 12v shut off when connected to panel board
                06-08-2021, 09:29 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
