Sony KDL-48W657D (main board protect, green light steady at the same time red light s
  • FMstatic
    • Jun 2021
    • 5
    • Philippines
    Diagnose (panel problem)
    - main board replaced- still no good
    - panel board check all supply present and correct voltage
    - hang flex ribbon main board to panel (error 5blink) but when connected again nonstop red blink no pose and green light steady
    -SDA and SCL supply 3.3v panel board
    -BL is good simulated
    Guys help me any suggestion
    Main board protect 12v shut off when connected to panel board
  • FMstatic
    • Jun 2021
    • 5
    • Philippines
    Re: Sony KDL-48W657D (main board protect, green light steady at the same time red lig
    Main board replaced due to mcu BGA damage
    • FMstatic
      • Jun 2021
      • 5
      • Philippines
      Where do i get the panel board diagram?
      How to bypass main board protect to panel to see the condition of panel appearance
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • howardc64
        A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
