Samsung LN32A330 dark ring around screen
  • OneAn9ryN00b
    • Dec 2011
    • 32
    So I fixed the tcon board on this tv i found off craigslist, and now notice a dark ring around the screen.
    Im posting a pic of what it looks like. Its not bad, on white screen, but noticeable on darker screens. Is this an image burn-in, or a ccfl light getting ready to go? AKA is this going to get worse anytime soon, or just stay like this for a while?
    Also if it is an image burn-in problem, would running one of those burn-in screen fixing videos work?
    Or is this an inverter problem? Or is this even reparable?
    Thanks in advanced.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung LN32A330 dark ring around screen
    Looks to be something to do with the diffuser....
    TELEFIX
    • OneAn9ryN00b
      • Dec 2011
      • 32
      How would one go about changing one of those?
      Is that a replaceable part?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        It's a part of the LCD panel itself. Replaceable yes, but a huge pain in the rear.
        A working TV? How boring!
        • Clydeuk
          • Jan 2012
          • 193
          I have a 26 inch Sony with this problem, it's barely noticeable but of course I spotted it on dark scene and now see it easily. In all other respects the picture is perfect, and the effect is hard to see if you are in direct line of sight. I've concluded a diffuser problem as well. But where can you obtain these other than from a scrap panel?
          By the way the panel in my Sony is manufactured by AU Optronics, I wonder if this is a common problem, I know Samsung (and others) use various panels in small to medium screen models.
          I'm reluctant to strip mine down on this occasion since it's really not that bad.
          • OneAn9ryN00b
            • Dec 2011
            • 32
            Dang....ok so next question. Is this going to get worse until i have no picture at all, or is this the extent of it?
            • mmartell
              • Oct 2013
              • 3189
              I can't see the damn thing! However it may be that the diffuser has come loose from whatever means they use to secure itin place and is scattering light unevenly. My guess would be you could just resecure it but getting to the thing is the hardest part of course.
              • mmartell
                • Oct 2013
                • 3189
                Oh I see it now - around the edge of the panel. I'm sure if you tore it down you would see what was causing it. Good luck.
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                  by JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                  No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                  Please help. Thanks in advance!
                  08-12-2025, 11:45 AM
                • Kiberge
                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                  by Kiberge
                  HI guys!
                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                  04-22-2024, 11:28 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
