Philips 65OLED818/12 FZ1
  • nlc2000
    • Jun 2015
    • Slovenija
    I recently installed a new SSB board (model from ASWO) in my Philips 65OLED818/12 FZ1 television after the original board failed due to a lightning strike. The TV now powers on and the Ambilight works, but there is no picture displayed.
    I believe the panel ID is TPM23.1E, but I can provide the exact panel code if needed.
    Could you provide the correct NVM.bin file for this model and panel? If there is another solution—such as firmware or service mode initialization—I would greatly appreciate your guidance.
    Thank you in advance for your help.
  • Diah
    • Feb 2013
    • 6496
    if yours panel TPM22, follow this instruction to turn it on the screen and change the OLED at Factory mode
    This attachment will be delete in 24 hours
    • nlc2000
      • Jun 2015
      • Slovenija
      Thank you so much for this, i will try, but i'm sure that my panel is TPM23.1E. Do you have any solution for this model?
      • Diah
        • Feb 2013
        • 6496
        first step to inter Factory Mode are belong to the MB. so try that first
        use this method OLED8x8
        • William1967
          • Nov 2017
          • 217
          • Netherlands
          That's a chassis code and has nothing to do with a panel. If you search for TPM23.1E you will find the service manual.
          Programming the panel code and option numbers at the same time is done with the setoption number that you can find on the rear cover. It's a 3 digit number, to program the code press 062598 home xxx where xxx is the 3 digit code.
          • Diah
            • Feb 2013
            • 6496
            F ( Factory mode) will switch any panel ON., the file NVM.EED are include above to switch panel on
            • nlc2000
              • Jun 2015
              • Slovenija
              Thank you! I will try!
              • William1967
                • Nov 2017
                • 217
                • Netherlands
                You don't need a visible image to enter the set option code, as this also sets the options for the motherboard in question.
                • nomoresonys
                  • 12306
                  • U.S.
                  Is that the whole procedure if no display, 062598-home-the 3 digit code, then just turn tv off?
                  • William1967
                    • Nov 2017
                    • 217
                    • Netherlands
                    For devices manufactured before 2016, only the panel ID is changed, and the device automatically goes into standby mode when the code is accepted.
                    For devices manufactured from 2016 and up, not only the panel ID is changed, but all options are also configured. After entering the code, you must restart the TV manually. The set option code can also be entered using an NVM.eed file.
                    The procedure is the same for both types.
                    • nomoresonys
                      • 12306
                      • U.S.
                      Thank you William1967.
                      • bohaboha
                        PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                        by bohaboha
                        Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                        how to fix it thanks
                        02-05-2025, 09:23 PM
                      • Guerilla3
                        Philips 32PFH4101 - bad panel?
                        by Guerilla3
                        Hello guys, I need your opinion whether this panel is bad and should I pursue it further. Third photo: left side t-con cable disconnected.
                        11-22-2024, 12:54 PM
                      • howardc64
                        LG 49UJ6500 LCD panel lighter band that goes away
                        by howardc64
                        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                        02-19-2023, 12:13 AM
                      • triplefour
                        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                        by triplefour
                        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                        tcon is built into mainboard.
                        Only one cable goes to panel boards.
                        there is a cable from one panel board to the other that links them.
                        cost cutting measure that results in us having harder time to diagnose.
                        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                        07-28-2022, 07:59 PM
                      • Storyteller12
                        QN55Q60R Service Menu Panel Help
                        by Storyteller12
                        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                        01-13-2024, 01:57 PM
