Dynex dx-lcd32 power supply half dead
  • The Performer
    • May 2013
    • 60
    • United states
    Re: Dynex dx-lcd32 power supply half dead
    So I cant get any voltage readings on DC anywhere on ic901, but in AC I get 12v around all the pins, is this right?
    On another not, If I trace back a random line at D932 I get a voltage drop from 72v to 14v, (again this is with meter set on AC. Any thoughts?
      What do you use for ground for your probe? You are measuring DC voltages in the primary side of the circuit, you have to use the negative leg of the main filter cap as the ground ref point for your meter. Did you verify that IC 901 is FAN7529?
      • The Performer
        • May 2013
        • 60
        • United states
        Yessir, the Part number is correct. FAN7529
        And on the note of ground point, I've been using the chassis as my ground... And now I feel like a dumbass...
        But seriously, was this taught to do so somewhere that I missed? Im not sure I follow which cap is the main filter cap, do you mean C901 as in the first cap in parralell after power goes into the board?
          There are two on them, black laying side way and has 100uF 450VDC printing on it, so now I know that you did not use the correct ground point for the primary side of the circuits, please measure the DC voltage again RIGHT AT THE TWO LEGS of either one of the two main filter caps when TV is ON. Do not let the probes slip on you and do not touch anything on the board.
          • The Performer
            • May 2013
            • 60
            • United states
            165v DC at standby and drops to 160 DC at power on.
            Ok so now answer me this, the whole time I'm doing my testing I have the board unscrewed from the chassis, but I ran a jumper from the circuit board mounting tab to the chassis to recreate the original ground, is this wrong?
              That is fine, the secondary (cold side) ground is connected to the chassis.
              So we need to check the resistance of that PFC IC 901 between the ground pin 6 of IC 901 against all the other pin, no power to the board of course.
              Make sure to report if the reading is in Ohm, K Ohm, or M Ohm.
              • The Performer
                • May 2013
                • 60
                • United states
                #27
                Ok so resistance in relation to pin 6 is as followed,
                6-1 _ 66 ohms
                6-2 _ 53.8 ohms
                6-3 _ 86.5 ohms
                6-4 _ 307.8 ohms
                6-5 _ 15.03k ohms
                6-7 _ ---- nothing seems to be connected by looking at the board, and no reading from meter (weird because the schematic shows it goes to ... and what do you know R 965 is showing open...
                6-8 _ 41.9 ohms
                  Your IC is damaged due to shorted out Gate to Drain that is why the Gate drive resistor is blown open, you need to replace the MOSFET Q901 and the IC at the same time. You should also test the R921 (Source resistor) to see if it still shows <1 Ohm.
                  You also need to check the Gate discharge R/D network R932 (10 Ohms), and Diode D919 (1N4148) to see if they are damaged also.
                  You should also test the resistance again on the Gnd pad against all other pads when the IC is removed.
                  • The Performer
                    • May 2013
                    • 60
                    • United states
                    #29
                    Sweet action!
                    yup, after I investigated the r965 I found that r932 was reading wrong too. Well that being said, looks like I have some parts to order!
                    Now if you dont mind, how do you know from my readings that the IC is bad. I looked over the datasheet but it seemed kinda confusing.
                    And thank you everyone for everything so far,
                    It really shows genuine kindness when people are so nice to help all for the purpose of helping someone else learn.
                      Let me know the resistance reading of the Ground pin pad against all other pads of that IC after the IC is removed.
                      "Now if you dont mind, how do you know from my readings that the IC is bad" You look at the function blocks inside the IC then you know what you should expect what the reistance should be, yours are all very low, and the blown resistor also made it clear that lots of current has flown through the circuit.
                      • The Performer
                        • May 2013
                        • 60
                        • United states
                        #31
                        So now come to think about it, I do remember about a year ago finding that mosfet shorted and I replaced it, so it's a brand new one in there right now. I didnt know to check any of the components feeding it for issues.
                        So on terms of you knowing what the resistance should be, does that just come from years of crouched over these devices to know such things?
                        Also Bud, are most of you wizards electronic engineers? I'm hoping to get to go to college for this. Started college in 08 and didnt do so well, and just now getting to give it a shot again. Electronics is just one of those things I dont lose as much attention with in comparison to other subjects.
                          I would replace the MOSFET and the IC at the same time. If you look at the diagram inside the IC, you will see for example the on VCC pin8 which has Clamping Zener diode inside, it will not have 40 Ohms reading, it should be in 1000's of Ohm range.
                          Pin 1 (use for feed back to maintain also show low resistance, this is an input pin to the comparator and op amp input circuit, so to have 66 Ohms, that is bad, etc.
                          • The Performer
                            • May 2013
                            • 60
                            • United states
                            #33
                            Ok so update, got the IC 901, swapped it out, with the new one in place I did a check on q901 and it appears to be fine. Like I said, I found it shorted through my first tear down and replaced it then.
                            All in all, still no 24v and Im at more of a loss. Any ideas what to check next?
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • kevin_allein
                              Samsung QE 75 Q 7 FGMTZG Power Supply dead
                              by kevin_allein
                              Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                              In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                              Does anyone have schematics for that board ?
                              Any good tip, what could be the issue ?
                              02-27-2025, 12:15 PM
                            • khalillll
                              maxipower 400W Dead power supply repair
                              by khalillll
                              The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                              After checking, I replaced the UTC7606D IC to restore the 5VSB.
                              I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                              Replaced it again with another UTC7606D.
                              Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                              After checking again, I think the issue was with the UTC7520D IC.
                              Replaced it with a WT7520.
                              Result: PSU fully working again
                              09-27-2025, 05:06 AM
                            • KYBOSH
                              Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                              by KYBOSH
                              I have a floodlight-security camera that recently died on me.
                              its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                              Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                              07-01-2024, 06:54 AM
