Panasonic TH50PZ85U dead HDMI's
  • mvalent000
    • Feb 2012
    Hello all, It's been a while since I have posted. I have a Panny TH50pz85u that works but the HDMI inputs will not recognize when a source is plugged into them (there are a total of 3). The tv turns on, displays the language/welcome screen I have access to everything, volume, menu, picture, sound etc etc.
    I am going to guess there is an issue with the A board, but I wanted some expert input on this because my past experience was that an A board issue would shut the tv down and produce a blink code....not the case here.
    Thank you for any input!!
    Re: Panasonic TH50PZ85U dead HDMI's
    It is quite common with this model. A board is bad. Not all A board faults cause a blink code.
    • Ltank
      • Jun 2013
      • 776
      I found that many times a power surge knock out HDMI Ports.
      This ties the grounds together between the different pieces of equipment. They are usually the first to go.. it takes the HDMI chips or the main processors
      • tw2005
        • Oct 2011
        • 6458
        I have a dead HDMI port due to lightning on my 2010 TV, it runs normal with the dead port, no SOS triggered.
        • mvalent000
          • Feb 2012
          Thank you all for the information and quick replies!! I will be on the hunt for an A board!!
          Thanks again
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • rmacintosh
            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
            by rmacintosh
            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
            The symptoms of the tv ar as follows:
            • Plug AC in to back of TV
            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
            • The 3 blink code is given by the power LED
            • If the TV is unplugged and then
            03-14-2020, 12:24 AM
          • nervx
            Panasonic TH-42PZ800 8-blink error mystery
            by nervx
            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
            04-08-2022, 05:19 AM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
