Sony KD - 65XF9005 - No image, sound OK
  • domix
    • Jan 2014
    • 167
    • Slovenia
    at tv KD - 65XF9005 i have a problem.
    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
    is this a common problem for this tv?
    i attached pictures of inside. Supply board looks okey, no blowed caps.
  • domix
    • Jan 2014
    • 167
    • Slovenia
    anyone have any suggestions
      • 12212
      • U.S.
      So what is it doing, works correctly for 10-30 minutes or black screen all the time?
      • EazyBone
        • Jun 2023
        • 1351
        • United states
        When it goes black take a flashlight to screen and get really close. Do you have a picture? It will be very dim so take your time looking for it
        • domix
          • Jan 2014
          • 167
          • Slovenia
          When go black, than is no picture even no with flashlight, backlight is off.
          I think because TV is mounted in the wall in a drywall niche, and have ony half a cm free space. I think its overheated at the back. Now i have it withaout a back cover ona a table, and now is turned on 4hours and everything is fine.
          now radiators on montherboard come to 80degrees. I think when is in the wall this temps goes way up.
          • EazyBone
            • Jun 2023
            • 1351
            • United states
            I would look for the picture again when it's black. I am a TV installer and we install all TVs as close to the wall as they can get . Going black with sound is a indication of backlights going bad.. so I would look again when it happens again. Is this an edgelit tv?
            • tiki66
              • Jul 2016
              • 47
              • Croatia
              Does the LCD turn off or does the backlight turn off?!
              @EazyBone it's and FALD tv with LD board, same principle as that 85x90CK you did the other day. If it was backlight error, it should trigger 4x red blink
              • domix
                • Jan 2014
                • 167
                • Slovenia
                After 8 hours of youtube 4k video i get this on screen. Turn off for 5 minutes, then image is back
                • domix
                  • Jan 2014
                  • 167
                  • Slovenia
                  Me again, tv was works now one month perfectly. Now it is 10cm out from wall niche.
                  Yesterday was working fine, but suddenly image shake, than goes black but sound was okey. I turn it off. Today same problem. If i check with flashlight, it black no image, but backlight is on :/
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4407
                    • Italy - Milan
                    No need of flash light, it is bad screen lcd, or in second option bad cpu soldering, especially if no separate tcon, but Sony usually has it separate.. third option bad bga on tcon.. same two damn fault types as always, no chance for these crap products..
                    • Diah
                      • Feb 2013
                      • 6405
                      XF90 series its SoC MediaTek MT5891 when it have BGA issue, screen will show as yours photo in post #8 ... re fellow it
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                        Sony xbr65x900c sound yes, no backlight or image.
                        by nomoresonys
                        Another troublesome sony: Just the facts. Tv was on, went off with 4 red blinks, messed around unplugging boards, testing cleaning, 4 red blinks went away, next turn on would get blinking green amber, then tried updating, nothing seemed to change so stopped that. Next I would turn it on get the steady amber/green blinking, I hit power on remote and it changes to steady dim white light, would get the android music but nothing but a black screen, no backlight, no image with a torch that I could see. Then made a mistake not letting it dry long enough after cleaning with iso alch and blew up the...
                        01-14-2022, 04:28 PM
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • Kartowl
                        philips 47pfl6158k/12 image faded away, sound still coming from TV
                        by Kartowl
                        Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                        04-23-2024, 12:57 AM
                      • Akuanka
                        Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                        by Akuanka
                        I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                        Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                        Thanks in advance for your help!
                        11-23-2024, 01:12 PM
