Hisense 65R6E3 double-image / horizontal strips - TCON?
  • nomoresonys
    • 12335
    • U.S.
    Originally posted by Diah
    any TV with T-CON had SPI firmware on it,
    jason123:
    MB disconnected from PSU and the LVDS disconnected from T-CON side..
    PSU as stand alone STBY connected to power on BL on and if there T-CON on too. 12V from PSU we take it direct to T-CON fuse. so yours LED BL will work and the Screen started in test mode.
    Thank you friend.
    • jason123
      • Oct 2015
      • 1157
      No luck with the TCON only - I get nothing on the screen - BL is on and 12 V to TCON. I got a replacement TCON, same result. Likely panel is toast? what are the chances the main board is bad?
      • Unspun01
        • Jun 2011
        • 349
        I had an LG 50" TV with similar issue a few years ago. Top 25% was perfect, and lower 75% had intermittent perfect image with horizontal tearing every second or so.
        I disconnected the LHS and RHS lower panel buffer boards independently from the TCON during testing but cannot recall the result. I was ready to toss the TV due to a panel problem when I discovered the scotch tape fix which works by masking some of the clock lines on the ribbon cables between the TCON board and the panel buffer boards.
        My TV was fixed. with clear scotch tape. It had very similar display problem to yours with some of it being perfect/unaffected, and other areas of the screen having lines, or loss of resolution, or flickering.
        I can't say it will help your TV since you say the lines are same whether LHS or RHS is disconnected from TCON, but my TV with similar problem had a panel issue. I would not spend money on a new TCON since I don't think it is your issue.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • Kingfreddie
          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
          by Kingfreddie
          Ok.. this is the story:
          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
          This is kinda how it looked, just that mine were at the bottom of the screen:
          09-11-2021, 01:57 AM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
