Vizio M65-C1
  • mrtek
    • Oct 2010
    • 51
    Vizio M65-C1
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV Click image for larger version
ID:	3682443This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED Drivers. Why 2 boards and what is the function of each one? Click image for larger version
Name:	LED Drivers_2.jpg
ID:	3682445Click image for larger version
Name:	LED Drivers.jpg
    When power cord is connected to PS board, one RED LED on main board turns on and stays onClick image for larger version
    . Checked voltages at power board and everything looks normal. I have +24V, +19V. The other connector going to main board has :
    ON / OFF = .147V
    Dim = 3.3V
    PS _ON = 3.6V
    When power button is pressed, a smaller Pink LED turns on next to the RED one and stays on Click image for larger version
ID:	3682440 until power button is pressed again. The power LED indicator turns on and fades away. When power button is turned OFF, the RED led stays on. No indication of LED turning on or Vizio LOGO on TV
    Removed main board Click image for larger version
ID:	3682442 and check ed some capacitors under one of the main CPU and noticed that some them, measure between 7-10 ohms. Click image for larger version
Name:	Faulty capsjpg.jpg
    Removed all the capacitors in questions but small resistance value is still there. So, I am assuming that somehow the main board is defective and the fact that I read that small resistance value accross those capaitors is an indicator that either and internal short / has happened.
    Wanted to be sure I am not missing anything before I order a new main board.
    Thank you in advance for any suggestions.
    Massimo
  • howardc64
    • Jun 2017
    • 622
    Most common failure is cracked BGA solder balls on the main board BGA chips under the 2 depressed rectangles in the heat sink. Proper BGA removal and reflow is necessary for long term fix (over bake or hot air gun/dryer fix usually don't last long) And need to know enough about heating boards to not do more damage (cold garage floor on bottom and hot air on top will usually warp + crack something)
    https://www.youtube.com/watch?v=XjB5vwSqDg0
    https://www.google.com/search?q=m65-...t=gws-wiz-serp
    On main board, not all low ohm caps are shorts. SOC CPUs need ~1v and operates in GHz speeds. So their voltage rail filtering caps to ground is super low resistance. Think of it this way, if you need to clock fast to GHz, need low resistance So if the caps are on low voltage rails (1v = CPUs/GPUs, 1.8v = DRAM, 3.3v = eMMC), its likely the correct design.
    BTW, easy solution of just replacing the main board are often costly on these Vizios with similar shaped heat sinks. Its because so many fail and most people don't have access to proper BGA remove/reflow equipment like above video. So pricy due to low supply and high demand.
    • EazyBone
      • Jun 2023
      • 1320
      • United states
      Yea id agree, likely a reflow of bgs chip. I have this exact TV same problem. Although I didn't watch the main board while reflow and it bent it and no longer works lol so oh well.
      • lotas
        • Jan 2016
        • 4577
        • Russia
        The board should heat up evenly over the entire surface, without bottom heating the board warps and becomes deformed and such a board cannot be repaired, since the BGA chip will no longer lie evenly on the surface of the board...
        • EazyBone
          • Jun 2023
          • 1320
          • United states
          Yup figured this one out.
          • mrtek
            • Oct 2010
            • 51
            I know, I have researched these main boards and they go for $150 Some companies offer BGA reflow services but it looks like to me that my board has been worked on.
            How hot these heat sink get? I have seen a guy placing a fan on top of the bga heat sink thru a cutout in the rear panel. He claimed it worked. I am sure it would help but for how long , is the question.
            • howardc64
              • Jun 2017
              • 622
              A lot of variables. Google BGA ball cracking to see microscope pics of the fracture. If just remelt, the cracks oxidize so will recrack easily. If prior incorrectly heated, then warp might have occurred and if bga doesn’t sit perfectly flat, the solder ball soldering will be uneven across the chip.
              anyway no way to know. Best is proper bga removal / reball / reflow.
              • mrtek
                • Oct 2010
                • 51
                After further inspection I have noticed that maybe some components are missing from this device on the bottom side of the board close to the connector that carries signal to the power supply.
ID:	3685570 Click image for larger version
                can anybody help me confirm if those locations are filled? what about the value ?
                Thank you
                Massimo
                • howardc64
                  • Jun 2017
                  • 622
                  Thank you
                  Massimo
                  Generally, not all pads are stuffed with components.
                  Unfortunately, the section is below bottom heat sink so not many pics show such area
                  https://www.shopjimmy.com/vizio-756t...masnar-serial/
                  You can go through posts for searching "M65-C1" on badcaps.
                  https://www.badcaps.net/search?q=m65...22m65-c1%22%7D
                  These ~2015 era Vizio main boards with BGA failures all look similar. Here is a video for heat sink removal but probably too low resolution and blurry from video motion blur to see area clearly
                  https://www.youtube.com/watch?v=TX6qu3m2O2M
                    • 12144
                    • U.S.
                    Have seen good results from people having a fan blowing right on the bga and lasting a long time but not near as good results if a fan is just sucking or pushing from other locations. So if you cut out a little section of the back panel right at bga, let it blow on not suck out.
                    • mrtek
                      • Oct 2010
                      • 51
                      Thank you for the info.
                        • 12144
                        • U.S.
                        [QUOTE=howardc64;n3685611]
                          • 12144
                          • U.S.
                            • 12144
                            • U.S.
                            Click image for larger version  Name:	Main_bd_connector.jpg Views:	0 Size:	279.4 KB ID:	3685570 Click image for larger version  Name:	Missing_Comp.jpg Views:	0 Size:	652.2 KB ID:	3685571
                            Thank you
                            Massimo
                            Might want to make sure your solder joint there in the picture is good, not cracked, in that c706, c705 area, maybe touch it up with a bit of flux and new solder.
                            • Unspun01
                              • Jun 2011
                              • 339
                              I have a 65" Vizio TV model D65U-D2 with a motherboard that looks similar to yours with the large black heat sink. Mine turns on and works, but sometimes suffers multiple reboots until it stays on successfully. Also sometimes has random menu lockups and video/glitches. Is this a BGA problem, or EEPROM failure? I wonder if we have similar issue?
                              When my TV works the video is very nice. Many times I can get TV to lock up when trying to change inputs. Weird issue.
                                • 12144
                                • U.S.
                                What have you tried. I try simple first, factory reset: navigate to the system settings menu, locate the reset option, and confirm the reset. Another simple reset to try, unplug tv from power-wait 4 minutes-hold down power button on tv for 38 seconds-plug tv back in and try it. Try those simple things if you have not. After that I would check the expected voltages at connector going from powerboard to mainboard on powerboard side, see if they are as expected, maybe check them when tv is acting correctly and when it's acting up.
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • cheeky2
                                  by cheeky2
                                  05-25-2024, 03:27 AM
