M470NV Vizio Consistently Spaced Horizontal Lines
  • gidianton
    • Aug 2014
    • 3
    I haven't been able to find the same issue as I am reporting on the forum. I am attaching an image of what the problem looks like. The lines appeared recently a couple of days after moving the tv to a new location. The tv was working perfectly then one morning the lines appeared. I'm thinking something got bumped loose - maybe a ribbon cable from what Ive been reading. The lines go a little thicker then back to their normal size on the lefthand side of the screen producing a very subtle dimming/brightening effect.I have tried replacing the power cable and checking the border of the tv by squeezing around it but the problem remains. If anybody has seen this issue, I'd greatly appreciate any ideas or insights.
    Thank you for your time
  • R_J
    • 9588
    Re: M470NV Vizio Consistently Spaced Horizontal Lines
    There could be some bad capacitors in one of the power supplies, If the cap. is bad it is not filtering the power supplies ripple and this could show up as lines in the video.
    • brad2157
      Vizio E70-E3 Two white vertical lines
      by brad2157
      I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
      Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
      Replacement main board - Boots up fine, but starting...
      12-13-2021, 05:11 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • x_orange90_x
      Vizio V585-J01 dancing lines and image doubling
      by x_orange90_x
      I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
      Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
      Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
      I swapped...
      06-12-2024, 07:57 AM
    • viking509
      vizio e65 e3 LED tv color vertical lines center tv only
      by viking509
      I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
      03-21-2023, 12:48 AM
