Hisense LCD42W60P Television
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi Guys,
    I have this 2008 lcd tv that uses ccfl lamps. The tv is stuck on standby. This is what I have noticed. The standby 5Vs voltage is not 5V but rather 3.28V. There is a 14V rail as well but that measures ok. I put my volt meter on the 5Vs rail and switch on the 220Vac. I noticed that the 5Vs rail goes to 5.1V and quicky changes to 3 28V and steady.
    I unplugged the main board and ccfl lamp wires and tested the power supply separate from the tv without load and put a 470 ohm resistor to the stby rail to force the tv on.
    1. Pfc circuit activates and mains smoothing cap is at 389v DC.
    2. The 5vs rail is 5.1V
    The 14v is at 16v (probably no load)
    You think there is a short on the main board, right. I checked that, no short or low ohms.
    3. I heated all the electrolytics and it made no difference. I even checked them with my esr meter, no fault
    Then, if you look at my photos you will notice a voltage rail specification. The 14V is rated at 1.5A.
    I put in a large resistor as a load on the 5V and 14V rail. I drove it at 50% of rated current and the PSU 5Vs rail dropped to 2.8V.
    It appears the set cannot run under load.
    the pwm chip is 1207AP. I think its NCP1207AP
    Is there anything i can check? I do have a scope. I can check if the set is chopping the dc correct or running in burst mode for example. I suspect a zener or resistor has changed, not sure. Sorry. I am not at work now to take clear full photos of the PSU.
    Any suggestions?
    regards
    Angelos
  • lotas
    • Jan 2016
    • 4787
    • Russia
    Maybe the firmware on the motherboard has crashed, what is the motherboard number?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4503
      • Italy - Milan
      Hi Angelos, the fault is within the PS board for sure, if you loaded the 5v_M (m=main, s=standby) and it dropped then watch the main stage and follow the feedback circuit, on the secondary you have to replace the shunt refulator (TL431 or like).. other issues can reduce the voltage, for example, if the tv set was in other's hands, he can have changed the big resistor less.than a ohm on the mosfet source for a wrong value, etc etc..
      ps: check the capacity of the main smoothing 450v capacitors
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4503
        • Italy - Milan
        I think too many people sleeping in this site...
        • angelos
          • Dec 2012
          • 573
          • South Africa
          Hi Davi,
          I am definitely not having a nap.
          I am looking for the NCP1207AP chip, i have alrerady got TL431 and also PC817 but i want all the parts before i reopen the tv.
          I need to get it sorted out. Unfortunately i only get to work on weekends to do repairs as i have a primary job.
          I will check you informed when i have more info.
          Thanks for keeping an eye on me.
          Regards
          Angelos
            • 12306
            • U.S.
            Well what I think he meant, is that everybody here except for him is stupid.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4503
              • Italy - Milan
              "Nomorecazzy":
              someone helps this person to find the users filter function, so i do not read his useless posts again.. i have read also his post where he abandoned the forum (for the 30th time), then he deleted it because he has nothing else to do than enter here with all exept real technical questions.. your posts value=0..
              Angelos: ok leave at least a sign you have read the post.. there are many and many dead threads where i put my effort and no more life in discussion after.. sad..
              depends on each user but i observe this always more..
                • 12306
                • U.S.
                I know you can't comprehend English, no matter how long you have been trying so then why don't you explain what you meant by that remark about everyone sleeping. nitwit.
                • Diah
                  • Feb 2013
                  • 6473
                  don't bother with rubbish poster... " users are sleep "
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4503
                    • Italy - Milan
                    And the other one demented at the follow, 2 cancers at price of 1
                      • 12306
                      • U.S.
                      You are correct sir, I have yet to see him solve anything but the simplest problems, yet he claims to be a master tech, laughable.
                      • CapLeaker
                        Leaking Member
                        • 8340
                        Right on.
                        • CapLeaker
                          Leaking Member
                          • 8340
                          Like diah already said: don’t even bother. It’s wasted time you don’t get back. Master tech? My
                          • angelos
                            • Dec 2012
                            • 573
                            • South Africa
                            "Nomorecazzy":
                            I am here Davi, i am going to work on the unit on Saturday. Then i will update.
                            Regards
                            Angelos
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4503
                              • Italy - Milan
                              Yes, if the band of bastards do not pollute every discussion, maybe the bar are closing all.. it's light and clear , some like Nomorecazzy enters threads only to attack.. they have nothing to do all day..
                                • 12306
                                • U.S.
                                +1,000,000
                                  • 12306
                                  • U.S.
                                  Uh oh, careful you guys, davi boY might challenge you to a MASTER TECH DUEL. hes gonna lose tho. I wish Budm was still here, he could always point out how wrong this guy is too.
                                  • CapLeaker
                                    Leaking Member
                                    • 8340
                                    I miss Budm too.
                                    • angelos
                                      • Dec 2012
                                      • 573
                                      • South Africa
                                      Hi Davi,
                                      I finally received all the parts that i needed to diagnose the fault.
                                      The mains smoothing cap measures 215uf @ 0.62 ohms ESR (should be a 220uf), no issue there. I mean i do get 390V DC on the cap when PFC circuit is enabled.
                                      I then changed the TL431, PC817 and the NCP1207A. There was no difference.
                                      I am going to have a look now at individual components on the feedback circuit, one by one i will remove them and test them. Will also replace all electroytics just for safety.
                                      I will also upload a full view of the power supply, perhaps it rings a bell for someone?
                                      Regards
                                      A Anagnostou
                                      • angelos
                                        • Dec 2012
                                        • 573
                                        • South Africa
                                        Hi guys,
                                        I don't know what I did previously but I over complicated things. There was a electrolytic (470uf 16V) that i had measured directly in circuit with my ESR meter and this was my mistake.
                                        I measured fine in circuit but in fact it was 450uf @5 ohms. I feel like a real dumbass. Must have had a bad day. LOL. Check picture. This cap sits on the feedback circuit to the TL431 and opto. Duh?
                                        So its fixed and on a soak test. Thanks for your comments guys.
                                        Regards
                                        Angelos
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • bimole
                                          Weird behavior on 3.3V rail of a CORSAIR CX600
                                          by bimole
                                          A colleague gave me an apparently ill CORSAIR CX600.
                                          He told me that he heard a banging noise, and smelt the magic smoke.
                                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                          It's another story on the 3.3V rail...
                                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                          02-13-2025, 04:49 AM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
