Westinghouse SK32H570D Blue screen of death with a code
  • hezandry
    hezandry
    • Oct 2012
    • 16
    • U.S.A.
    Hello all, Have an older Westinghouse, found and replaced a burnt out backlight inverter. Tv came right on, nice clear image. After about ten seconds the blue screen of death appeared as an 8" horizontal band across the middle of the screen with the code (?) "18G1W016 Factory". Tv comes on when plugged in without pressing the power button, none of the buttons have any effect.
    A search of the web and westinghouse has provided zero info. Hoping someone here can give some insight.
    Thanks much
    Hezandry
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Westinghouse SK32H570D Blue screen of death with a code
    has this got a internall dvd player? if it has unplug all power to the dvd drive and see if the tv starts ok ive read this on various forums via google seems a issue with the dvd drives.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Tou could aways try this - its from an old forum post but you never know your luck
      i
      f you still need this message removed from your TV please email me to westytech@westinghousedigital.com, please provide me the model # as well as the TW# located on the back of the TV and I will make that box go away.
      • hezandry
        hezandry
        • Oct 2012
        • 16
        • U.S.A.
        Thanks, Unplugged both the power and data cables. No blue screen, but initially had issue that none of the control buttons except power button worked. Hot plugged the dvd power and buttons worked, then unplugged hot, buttons continued to work. Now a 72 hour test with a lot of button pushing.
        Thanks for the replies!
          • 31269
          if you can find the code for the factory menu, you can probably set it to not have a dvd drive.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • ulthi
            Samsung QE50Q60TAU - Flashes black/blue screen
            by ulthi
            My tv is not able to turn on. I flashes between black and vague blue screen (see video)
            I have tried different resets and have also replaced the main board - but nothin has changed.
            Any suggestions?
            https://youtu.be/acYQ-ImmhWA
            10-14-2025, 01:48 PM
          • Wardy
            Acer Aspire 3 Blue screen of death.
            by Wardy
            Hi, I have got a Acer Aspire 3 laptop that won't boot properly. I keep getting the below stop codes;
            IRQL_NOT_GREATER_OR_EQUAL
            PAGE_FAULT_IN_NONPAGED_AREA
            'DRIVER IRQL NOT LESS OR EQUAL'
            I have tried to install a fresh windows 10 home but it crashes before it can finish it's full install. I have also cleaned the RAM slot. Tried an external drive HDD with windows 10 home installed via USB and still the same issue. Also tried resetting the laptop via windows but still the same thing.
            Has anyone got any ideas why this is happening...
            01-08-2023, 06:40 PM
