Samsung UN55ES6100F - has power and audio, no picture
  • Audioplus
    • Feb 2012
    • 157
    Samsung UN55ES6100F No Video, But Has Power And Audio, Not Sure Yet If Graphics Can Be Seen With Flashlight.
    Any Ideas As Yet?
    Thanks, Dan C
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung UN55ES6100F - has power and audio, no picture
    LED problem, take the back off and post photos of the boards as detailed as you can.
    • Audioplus
      • Feb 2012
      • 157
      Not a backlight issue either, I don't have access to set yet. Mainboard as a guess?
        A lot of newer "no picture with backlight" faults are bad panels....
        • Audioplus
          • Feb 2012
          • 157
          When it powers up, very dark blue display, you can tell it wants to do something, but no graphics. An associate, mentor commented 99% chance that it's a power supply issue.
          Any thoughts?
          • Audioplus
            • Feb 2012
            • 157
            Replaced power board, no change, same issue, any ideas?
            • mmartell
              • Oct 2013
              • 3189
              Tcon ?
              • Audioplus
                • Feb 2012
                • 157
                A little confused, some of these ES series the T-Con is part of the panel? Can anyone confirm the following?
                Troubleshooting T-Con/Panel can begin by measuring the operating voltage in from the
                Main Board LVDS Cable at both sides of FP1.
                -If the 12V supply appears on both sides of the fuse (with meter reference to chassis
                ground), a correct supply is given and used by the T-Con.
                -If the 12V only appears at the LVDS Cable End of the Fuse. The fuse is open and TCon/
                Panel needs to be replaced. Sometime replacing a fuse will correct the failure,
                however, before proceeding, check for any bulletins related to this condition.
                -If the 12V does not appear on either end of the fuse, the LVDS Cable and Main Board feeds
                need to be checked and LVDS Cable or Main board replaced. ALSO: check that the 12V
                supply feed from the Power Supply to the Main board is present.
                • Audioplus
                  • Feb 2012
                  • 157
                  I'm going to try a T-Con, will confirm operation when I receive.
                  • Audioplus
                    • Feb 2012
                    • 157
                    T-Con was the issue, replaced with new (TriState), success!
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
                    • grimreaper420
                      Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
                      by grimreaper420
                      hey guys,
                      i bought 2 samsung odyssey g9's for a decent price. they both have the exact same fault. when plugged into a power source, the blue led powerlight shows, but when turned on there is no picture, no backlight, no menu, nothing. when plugged into a laptop the laptop recognises the monitor, but keeps disconnecting and reconnecting.
                      dont have any schematics or diagrams unfortunately. any ideas?
                      thanks
                      09-03-2024, 03:47 AM
