Samsung UN55ES6100F - has power and audio, no picture
  • Audioplus
    • Feb 2012
    • 157
    Samsung UN55ES6100F No Video, But Has Power And Audio, Not Sure Yet If Graphics Can Be Seen With Flashlight.
    Any Ideas As Yet?
    Thanks, Dan C
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung UN55ES6100F - has power and audio, no picture
    LED problem, take the back off and post photos of the boards as detailed as you can.
    • Audioplus
      • Feb 2012
      • 157
      Not a backlight issue either, I don't have access to set yet. Mainboard as a guess?
        A lot of newer "no picture with backlight" faults are bad panels....
        • Audioplus
          • Feb 2012
          • 157
          When it powers up, very dark blue display, you can tell it wants to do something, but no graphics. An associate, mentor commented 99% chance that it's a power supply issue.
          Any thoughts?
          • Audioplus
            • Feb 2012
            • 157
            Replaced power board, no change, same issue, any ideas?
            • mmartell
              • Oct 2013
              • 3189
              Tcon ?
              • Audioplus
                • Feb 2012
                • 157
                A little confused, some of these ES series the T-Con is part of the panel? Can anyone confirm the following?
                Troubleshooting T-Con/Panel can begin by measuring the operating voltage in from the
                Main Board LVDS Cable at both sides of FP1.
                -If the 12V supply appears on both sides of the fuse (with meter reference to chassis
                ground), a correct supply is given and used by the T-Con.
                -If the 12V only appears at the LVDS Cable End of the Fuse. The fuse is open and TCon/
                Panel needs to be replaced. Sometime replacing a fuse will correct the failure,
                however, before proceeding, check for any bulletins related to this condition.
                -If the 12V does not appear on either end of the fuse, the LVDS Cable and Main Board feeds
                need to be checked and LVDS Cable or Main board replaced. ALSO: check that the 12V
                supply feed from the Power Supply to the Main board is present.
                • Audioplus
                  • Feb 2012
                  • 157
                  I'm going to try a T-Con, will confirm operation when I receive.
                  • Audioplus
                    • Feb 2012
                    • 157
                    T-Con was the issue, replaced with new (TriState), success!
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • grimreaper420
                      Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
                      by grimreaper420
                      hey guys,
                      i bought 2 samsung odyssey g9's for a decent price. they both have the exact same fault. when plugged into a power source, the blue led powerlight shows, but when turned on there is no picture, no backlight, no menu, nothing. when plugged into a laptop the laptop recognises the monitor, but keeps disconnecting and reconnecting.
                      dont have any schematics or diagrams unfortunately. any ideas?
                      thanks
                      09-03-2024, 03:47 AM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
