Vizio D65x-G4 Volume changes on its own
  • karthur
    • Nov 2015
    • 150
    Thanks guys for those suggestions.
    I did check the resistance across the buttons when they were pressed/not pressed. They all seemed to be working fine. When pressed they were like 0.2 ohms and 1mega ohms when not pressed. I see what Lotas posted above in post #16. I can look at those again.
    The "AutoVolume" is set to OFF in the settings.
    I have attached a pic of the board below. Yes, it appears to be similar to the one Lotas posted in post #9 above.
    I have tried to do an update, but it says I am up-to-date. I watched the YT video on the key sequence for the factory reset (vol down+Input). Will give that a shot tomorrow.
    • karthur
      • Nov 2015
      • 150
      I replaced the main board with one from ShopJimmy. Same problem. I have the key controller board coming. Should be here this week.
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        Just disconnect the key controller board and test it.
        • jlode675
          • Jul 2013
          • usa
          [QUOTE=karthur;n3660183]I replaced the main board with one from ShopJimmy. Same problem. I have the key controller board coming. Should be here this week
          • karthur
            • Nov 2015
            • 150
            I did disconnect the key controller and tested the buttons. Are you saying to disconnect the board and try to turn the TV on? I don't see how that would be possible with the board disconnected.
            • EazyBone
              • Jun 2023
              • 1347
              • United states
              #26
              Oh right, Vizio goes to power buttons then goes to remote light. Other tvs aren't that way whoops.
                • 12206
                • U.S.
                #27
                Any update?
                • karthur
                  • Nov 2015
                  • 150
                  I replaced the key controller board and it fixed the issue. However, after I replaced the KC board the TV would not connect to my wi-fi. I did a factory reset from the Main menu, then everything started working correctly.
                  I never did a factory reset using the original boards. I plan on putting both original boards back in and do a factory reset and just see if it still has the issue.
                  I am thinking it was the key controller board really.
                  Thanks for the help!
                    • 12206
                    • U.S.
                    #29
                    Yep, I think it was too, thanks for update.
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      07-14-2025, 07:28 PM
                    • crackedprint
                      Sony HCD-HX80R Amplifier Volume Control Problem
                      by crackedprint
                      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                      I have tried a Cold Reset as per the service manual.
                      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                      I have looked all the way through the service manual and tried many online...
                      01-21-2025, 12:18 PM
                    • BigOof
                      Marantz SR5007 popping on volume change and mute in Direct Mode
                      by BigOof
                      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                      12-12-2024, 06:15 AM
