Vizio D65x-G4 Volume changes on its own
  • karthur
    • Nov 2015
    • 150
    Thanks guys for those suggestions.
    I did check the resistance across the buttons when they were pressed/not pressed. They all seemed to be working fine. When pressed they were like 0.2 ohms and 1mega ohms when not pressed. I see what Lotas posted above in post #16. I can look at those again.
    The "AutoVolume" is set to OFF in the settings.
    I have attached a pic of the board below. Yes, it appears to be similar to the one Lotas posted in post #9 above.
    I have tried to do an update, but it says I am up-to-date. I watched the YT video on the key sequence for the factory reset (vol down+Input). Will give that a shot tomorrow.
    • karthur
      • Nov 2015
      • 150
      I replaced the main board with one from ShopJimmy. Same problem. I have the key controller board coming. Should be here this week.
      • EazyBone
        • Jun 2023
        • 1436
        • United states
        • Anything I can do with my hands
        Just disconnect the key controller board and test it.
        • jlode675
          • Jul 2013
          • usa
          [QUOTE=karthur;n3660183]I replaced the main board with one from ShopJimmy. Same problem. I have the key controller board coming. Should be here this week
          • karthur
            • Nov 2015
            • 150
            I did disconnect the key controller and tested the buttons. Are you saying to disconnect the board and try to turn the TV on? I don't see how that would be possible with the board disconnected.
            • EazyBone
              • Jun 2023
              • 1436
              • United states
              #26
              Oh right, Vizio goes to power buttons then goes to remote light. Other tvs aren't that way whoops.
              • nomoresonys
                • 12370
                • U.S.
                #27
                Any update?
                • karthur
                  • Nov 2015
                  • 150
                  I replaced the key controller board and it fixed the issue. However, after I replaced the KC board the TV would not connect to my wi-fi. I did a factory reset from the Main menu, then everything started working correctly.
                  I never did a factory reset using the original boards. I plan on putting both original boards back in and do a factory reset and just see if it still has the issue.
                  I am thinking it was the key controller board really.
                  Thanks for the help!
                  • nomoresonys
                    • 12370
                    • U.S.
                    #29
                    Yep, I think it was too, thanks for update.
