Sanyo DP42740 no power
  • triplefour
    • May 2014
    • 1747
    got my first plasma TV to attempt a repair on today.
    a friend of mine said if i can fix it we'll sell it and split the money.
    the people he got it from gave this story as to why its broken:
    "we were watching it, during a lightning storm, when it suddenly turned off and wouldn't turn back on again. nothing else in the house was affected. we were not hit by the lightning or anything"
    at any rate, i plugged it in and i do not get a standby light or anything and pushing the power does nothing.
    it has a million screws in the back for some reason. but i took them all out and got some pictures of the boards.
    i know that plasmas are much different from the LCD's so i dont really know what im looking at here.
    where should i start? on the LCD boards there is usually one big capacitor on the power board. the main filter cap. but on this board there are 4 big capacitors.
    is working on a plasma TV any more dangerous than LCD or LED tvs?
    Don't fear the repair...
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sanyo DP42740 no power
    No standby light would put the powersupply at first suspect I'd say.
    Is there a legend printed at the connector that goes to the mainboard?
    Assuming you already checked the fuses F201,F202,F204?
    First we need to figure out if you get the standby voltage.I'm trying to find a schematic..
    Working on plasma's is not more dangerous then a lcd tv,yes,there is the VA and VS voltage of 200+dc volt etc,but 1000volt plus on a lcd tv for inverter doesnt feel nice either
    Bigger caps on power supply you have to watch for,they hold a good charge for awhile after unplugging,best to drain them with a heavy resistor before poking around on that board(been there,done that,trust me,doesnt feel nice at all)
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      "borrowed" a picture from the psu
      http://www.toms-service-manuals.com/...h=Submit+Query
      There ya go for schematics,thank tom66 for his amazing database.super handy
      • triplefour
        • May 2014
        • 1747
        yeah thats what mine looks like...
        • triplefour
          • May 2014
          • 1747
          awesome. i guess i better go thru everything in this service manual and then report back. thanks!
          • johnboy1313
            • Nov 2012
            • 1959
            Set your meter to the highest DC volts setting and check across the leads on one of the big 450V caps at the top of the PSU, with the set plugged in. Red on one leg, black on the other. Report back.
            • selldoor
              Slow Learner
              • 7870
              A good in focus straight on picture of the front and back of the power supply might help.
              Not able to see much at all on the one you posted.
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                The big main caps are probably not active till the psu gets forced on. Might not see a voltage on those in standby.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  If the set is in standby, he should still see roughly 170V, if not roughly 400V. I had the same set with the same symptoms. My PSU was stuck ON.
                  https://www.badcaps.net/forum/showthread.php?t=28850
                  • triplefour
                    • May 2014
                    • 1747
                    i get no volts at the big caps (well the 2 i can test without turning over the board anyway)
                    and i only get 84v AC from the plug... shouldnt it be 120?
                    • triplefour
                      • May 2014
                      • 1747
                      at the very beginning of the service manual it says
                      "An isolation transformer must be connected in the power
                      line between the receiver and the AC line before any service
                      is performed on the receiver"
                      is this really true? what is an isolation transformer anyway?
                        It is for safety when you are probing around the Primary (Deadly) side of the circuit, you should have 120VAC right at the AC connector on the board. Is your meter's battery OK?
                        Example of Isolation transformer:
                        https://cdn.badcaps-static.com/pdfs/...4cc7e77847.pdf
                        • triplefour
                          • May 2014
                          • 1747
                          i dont think my meters battery is bad. i can test double A batteries and i get the same readings as with my analog meter...
                          • triplefour
                            • May 2014
                            • 1747
                            selldoor, in post 3 there is a clear picture of the power board (from the front anyway)
                            ill try to take a good one of the back.
                            • triplefour
                              • May 2014
                              • 1747
                              ok heres the pictures of the back. the board is pretty big so i couldnt take a detailed picture of the whole thing so i did it in sections as well.
                              • triplefour
                                • May 2014
                                • 1747
                                ok i re-tested the AC volts and i do get 120 now. i dunno what that 84v was about but its 120 now... how do i test for 5v standby? i get no volts across the capacitors. no volts across any of the fuses either. what should i use for ground ref to test the volts at the connectors? and how do i tell which one is standby? theres no legend anywhere!
                                  So you do not have aboyt 165~170VDC measured right at the two legs of the main filter caps (100uF 450VDC)?
                                  All three fuses show <1 Ohms? measure them with TV unplugged.
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    yes the fuses are not open. and with the tv plugged in i get 0v on the filter caps (the 2 i can measure without flipping the board over that is)
                                      OK, I will have to trace out the connections from each leg of the AC inlet all the way to the two inner legs of the bridge rectifier. That will take awhile. I did not download all the pictures of the bottom side of the board yet, hopefully they are clear enough for me to trace out the connections.
                                        OK, luckily shopjimmy has good pictures of the top and the bottom side of the board.
                                        http://www.shopjimmy.com/sanyo-n0ae5...ply-board.htm#
                                        You can test the board by itself to see if you are getting the DC Voltage on the filter cap CE203 which is the filter cap for the standby power supply, measure right at the two legs of the cap.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
