LG DRT389H DVD recorder
  • Greeno
    • Feb 2011
    • 36
    • Scotland
    Hi
    I realise it's not really worth the effort (I'm WAY past that point!) but I've started and I don't like to give up.
    I was given this by a friend because it would no longer recognise discs - the problem turned out to be the motor that spins the disc.
    Having resolved that issue, the player has quickly progressed to being essentially unusable.
    It's usually painfully unresponsive when first plugged in - tray won't eject/close; does not respond to the remote - but usually recovers.
    When watching a DVD or AVI (via USB or from disc) it will freeze/restart after anything up to an hour; sometimes it will display "Service is not running or scrambled" in place of the TV signal. After powering off and on, it might work again for up to 10 minutes before failing again.
    Voltages appear to be OK but since the problem is intermittent this may not mean much.
    No obvious capacitor failures.
    It seems that this is not an uncommon problem but I haven't been able to find any suggested fixes.
    I'm on the verge of replacing the main power supply capacitors, but the board is bristling with electrolytics and I don't really want to replace them all - especially since this may have nothing to do with the problem.
    So I thought I'd see if anyone here has any suggestions?
    Any advice would be greatly appreciated.
    • 31248
    Re: LG DRT389H DVD recorder
    there are nly about 9 capacitors related to the psu.
    the group under the transformer in the foto.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      unlikely to be the capacitors on the psu because you have the correct voltages,are they printed on the trace side?
      as it is an intermittent fault id be looking at a cold solder joint etc.
      ideally you would need an ESR meter to verify caps are good also it may well be a MCU/CPU issue as it happens after an hour or so,do any chips get very hot to touch?,you can blast the chips with freeze spray while the symptoms are happening if it corrects then its a thermal issue
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • Greeno
        • Feb 2011
        • 36
        • Scotland
        Hi, and thanks for your reply.
        Yes, voltages are printed on the board (top) AND I have the service manual (for what it's worth). There was a tiny fluctuation on the 5v but probably small enough to be within the margin of error of my meter (I think it 4.99-5.00).
        I have considered a bad connection and temperature (it has been relatively hot here recently). I have tested it with the case open and a computer case fan sitting above the board, with no noticeable effect. The "main" board in this recorder is actually part of the DVD drive module (so there's a lot of communication over those flat ribbon cables you can see in the picture) and it's not really possible to check the temperature of the main processor while it's running. I'll take another look.
        I should have given up a long time ago.
        Thanks for your time.
        • SteveNielsen
          Retired Tech
          • 2327
          Get a good picture of the bottom of the board and look for bad solder joints, etc.
          I say if you're learning something and enjoy it then it is not a waste of your time even if you never get it working.
          • ron77
            • Dec 2012
            • 63
            • united kingdom
            I got in touch with LG regarding this model. Downloaded an update file, not a cure all, of course, but found it very useful. LG were very helpful, that was about a year ago. Still have disc, and have, as I have said, found it useful.
            • fzabkar
              • Mar 2009
              • 772
              Service manual:
              • radioredcat
                • Nov 2008
                • 8
                I know this is an old thread but I thought the info I am going to provide will help someone.
                I have this model and connected it to antenna/HDMI and applied power and was greeted with a picture with a disk in top corner and no response from remote except power and mute button nothing else the DVD tray would not open it just says read that.s all.
                I put it on the bench and took the lid off and what do I see Chang/Gluxon caps anyway applying just power lead it worked ok hmmm.
                Took it back to TV applied just power all fine plugged HDMI in all ok then plugged antenna in it stops responding so it seems for some reason it doesn't like being earthed via the antenna lead.
                As it happens I only want it for playing DVDs and files from USB stick.
                Andy
                • Dabbler
                  • 10
                  • Scotland, UK
                  RADIOREDCAT.
                  OLD thread it may be, but still perfectly valid! I scratched my head for hours then tried here, found this and hey presto same condition!
                  Not sure there's an actual cure, but at least it's usable as a DVD!
                  Thanks very much, hope not too late to congratulate you, well done!
                  Alan (Dabbler, by nickname and habit!)
                  • Junior††
                    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                    by Junior††
                    Good Afternoon fellas,
                    Issue:
                    Disc is showing as not supported when a disc is put in.
                    Here's what I've done, you can skip this if you just wanna know the question:
                    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                    - reflowed the disc drive connector
                    -reflowed the chip in question (shown on image)
                    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                    Question:
                    I...
                    02-19-2025, 12:48 PM
                    DVR recorder Switching power supply Failure
                    by sam_sam_sam
                    When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                    Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                    This...
                    05-27-2023, 03:03 AM
                  • ahmedtou
                    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                    by ahmedtou
                    help me please
                    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                    I will share all the details with you, including the disc information.
                    Code:
                    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                    Current Profile: BD-R
                    Disc Information:
                    Status: Empty
                    State of Last Session: Empty
                    Erasable: No
                    Free Sectors: 12,219,392
                    Free Space: 25,025,314,816 bytes
                    Free Time: 2715:27:17 (MM:SS:FF)
                    Next
                    08-27-2025, 08:49 AM
                  • warsztat
                    Trademi Horizon, freeze after start.
                    by warsztat
                    Hi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
                    The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
                    All the multiplexers that support the display seem to be working. It's like the processor...
                    03-06-2025, 07:33 AM
                  • maleksa
                    Yamaha MOX8 boot freeze and distorted sound
                    by maleksa
                    My Yamaha MOX8 synthesizer recently developed two issues.
                    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                    11-07-2024, 03:28 AM
