Sanyo 30744 HDMI Port Issue
  • KTMLew
    • Sep 2011
    • 37
    Have a weird one. Just picked this TV up off CL a month or so ago.
    If I watch Netflix on HDMI setting, no sound until I cycle the TV on/off. Then when I try to change back to TV "input", it won't change until I cycle TV on/off?
    Netflix is through an el-cheapo Magnavox DVD player.
    WTF?
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • ratdude747
    Intel HDMI Windows 10 issue
    by ratdude747
    Got my butt kicked by windows 10 and intel last week.
    I have an HDMI switch and splitter setup for an AV rig (church) that I was trying to use the windows 10 half of my Lenovo T440s with. However, the audio will not work; HDMI (displayport) audio doesn't show in device manager and Intel's Control Center shows the external display as not supporting audio. Direct connect it to things and (if memory serves) it does work.
    Compounding the issue is that I'm forced to use Lenovo's drivers... as the generic intel ones refuse to install as they detect it's a lenovo system...
    12-04-2022, 07:34 AM
  • sebulica
    Asus FX705DT eDP and HDMI output issue
    by sebulica
    Hi
    I have an Asus FX705DT that had waterdamage....a lot
    I have managed to make the motherboard look like working but i stil have some issues and maybe someone can point me in the right direction.
    The laptop has a destroyed keyboard and the display is dead but i have managed to make the board start up and work "normal"...i have no short,power rails are looking good,hdd/ssd activity and so on.
    The problem is that there is no HDMI output,only sometimes makes the tv/monitor go black screen for a brief moment,and on the internal...
    04-06-2023, 04:44 AM
  • Ado02
    Dell Latitude 5510 USB-c Hdmi Issue
    by Ado02
    I am working on a Dell Latitude 5510 - the USB-c port has not HDMI output. The port works for data transfer and charging but not for HDMI.
    I check the USB-c port but can't see any damage.
    Has anyone experienced this problem and found a solution?
    04-05-2023, 02:55 AM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
