Samsung UE40D6000
+ More Options
Posts
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Samsung UE40D6000
    Turns on, backlight works, previous owner told that sound also works but screen is black.
    Took it apart and heard that t-con board was clicking very quietly. Part no. KR98BN95005.
    At first I disconnected panel from t-con board - still heard clicking sound.
    Then I disconnected t-con board from mainboard and clicking stopped.
    (Cause of some googling) I tried disconnecting and connecting main board cable from t-con board while turned on and didnt notice any flicker while doing that.
    Is it safe to say that t-con board is faulty and ordering a new board will fix the TV?
  • jose6326
    • May 2013
    • 707
    Re: Samsung UE40D6000
    post pictures of the board layout and close ups of all the boards
    • tibimakai
      • Jan 2012
      • 3680
      Try disconnecting one ribbon at a time, from T-con to panel.
      D series, suffers from bad panels.
        D series bad panels... I seriously cannot recall a faulty D series without a bad panel!!!
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Disconnecting one ribbon at a time from t-con to panel changed nothing. Or what should have happened?
          • mmartell
            • Oct 2013
            • 3189
            They also suffer from bad leds when the panel itself isn't bad.
              Due to the difficulty in repairing that I'm rolling that into bad panel myself, LEDs should last more than 3 yrs.
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                Tried eeprom reset - still nothing.
                When I tried switching sources, the screen flashed, so the only problem is black screen - everything else seems to be working fine.
                I remember the previous owner also told me that before this problem, there was one vertical and one horizontal one-pixel wide stripe. Could that be a hint of a tcon board that was about to die?
                • warteam
                  • Jun 2018
                  • 5
                  • TURKEY
                  Samsung ue40d6000 tv nand flash yazilimi olan varsa yardimlani rΔ°ca ederΔ°m..
                  • warteam
                    • Jun 2018
                    • 5
                    • TURKEY
                    If anyone has Samsung ue40d6000 tv nand flash software, please help..
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                      by ohren
                      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                      The models launched in 2018 and 2019 respectively....
                      09-08-2023, 05:24 PM
