Dynex DX-LCD37-09 Roadside find with intermittent video issues.
  • drewb0y
    • Jun 2010
    • 12
    I found this Dynex DX-LCD37-09 on the side of the road and at first glance it actually seemed to be in good shape. My brother in law hooked up his laptop into the vga input and declared it to be just fine after getting a good picture. I knew this would be too good to be true, however.
    So basically it has a good clear picture and sound most of the time, but intermittently and at random times, the screen goes mostly green lines and black for a bit, then it pops back to normal. So now I understand why someone had an excuse to buy a new TV, and hopefully not another Dynex.
    So I thought I would ask here if anyone has seen these particular symptoms before, and if they would have any suggestions. Or if it is even worth fixing. I have fixed plenty of monitors and LCD TV's with bad caps in the power supplies, mostly thanks to these forums.
    Here is a video I took of the TV in action. http://youtu.be/hG_jy8Oh8XA
    Thanks in advance for any help.
  • drewb0y
    • Jun 2010
    • 12
    Re: Dynex DX-LCD37-09 Roadside find with intermittent video issues.
    And by the way, I have not actually taken it apart yet, just wanted to see if this is a common problem first. I did locate a service manual at Elektrotanya, though.
    • DLinkOZ
      • May 2013
      • 238
      I had one recently with nearly the exact same problem as your video. The only difference being that once it cleared up, it stayed clear until you turned it off and let it sit for awhile. My thread is here:
      https://www.badcaps.net/forum/showthread.php?t=38521
      Despite hoping it was a tcon issue, it would seem as though the problem is actually in the panel since a replacement did not change the symptoms. Not even a little.
        Definitely panel. A t-con cannot/will not cause that fault.
        May be a Dynex brand TV but who made the panel? Wouldn't surprise me if it's a Samsung panel that has failed.
        • drewb0y
          • Jun 2010
          • 12
          It was a Samsung panel. After I took it apart and so absolutely no visible signs of either bad caps or solder joints, I decided it must be the panel. Oh well no money lost on this one at least! I definitely know from experience I will never buy a Dynex branded anything.
          This TV met it's final resting place in the local landfill yesterday!
          Thanks for the advice.
          Maybe next time I will find a salvageable unit. So far this year I have found 4 fixable LCD monitors at least.
            Just don't buy any TV that uses a Samsung panel. Including Samsung TVs. (Certain Samsung TVs use AUO or Chimei panels which are "OK".)
              • 31291
              Originally posted by drewb0y
              This TV met it's final resting place in the local landfill yesterday! .
              you should have sold the boards!!
              • gretti
                MSI Z370-A Pro, works but does not power off or reboot and USB issues
                by gretti
                I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                The MSI BIOS included the ME firmware for the board. The size...
                10-16-2025, 02:14 AM
              • protocold
                MacBook Pro 15" 2010 820-2850 intermittent charging
                by protocold
                I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                when it is not intermittent:
                PPVBAT_G3H_CHGR_R is 12.07v
                when it is intermittent:
                When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                data line on the battery...
                07-25-2025, 08:18 PM
              • thaphatmaster
                Another LG Flatron W2243S-PF monitor - intermittent power issues
                by thaphatmaster
                Afternoon all,
                Firstly, I'm glad I found this place via Mr Google.
                My LG Flatron W2243S-PF has had an intermittent fault for a looooong time The fault is:
                1. It simply turns off during use; or
                2. refuses to turn on, and
                3. flashes its red power light.
                4. It sometimes does this multiple times a day;
                5. it sometimes does this for weeks on end; and
                6. it sometimes works completely fine, for days or weeks on end.
                It's now in a period of having this fault, which is making it nigh on unusable. I am keen to repair it as I have lots of cool Nerf Gun 3d printing...
                04-03-2020, 09:50 AM
              • Nagyesz
                Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                by Nagyesz
                I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                How can I extend its lifespan? Could reflow help?
                It has ryzen 5 5500h, rtx 2050, no soldered ram.
                Example of the artifacts:
                03-01-2025, 11:11 AM
              • pwnjuice
                Bitlocker issues
                by pwnjuice
                Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                01-06-2025, 05:33 PM
