PDP-4304 solid red/green LEDs
  • brainiac88
    • Jun 2014
    • 21
    I have a Pioneer PDP-4304. It refused to turn on, so I did some initial troubleshooting a few months ago, and decided to replace the power supply. I installed the new power supply but did not know about this diabolical trap switch. So I turned it on and of course, it did not power up. Instead, I have solid red and green LEDs on the front. I also research as best I could on how to reset this trap switch through the remote, but that did not work either. Couple possibilities:
    1 - Something else was broken, not the power supply
    2 - The trap switch reset method I used was incorrect / ineffective
    3 - ???
    I verified that the remote does emit IR light by looking at the emitter using my phone's camera.
    Any ideas would be greatly appreciated.
  • brainiac88
    • Jun 2014
    • 21
    Re: PDP-4304 solid red/green LEDs
    Bump..
    Anyone?
    Help, please?
    • nuala
      • Aug 2013
      • 37
      Do you get any blinking code from the led after turning the set on.
      • brainiac88
        • Jun 2014
        • 21
        No blinking, just aolid red and solid green front LEDs...
        • R_J
          • 9628
          Trap Switch Reset Procedure
          G-4, G-5, G-6, G-7, G-8
          • Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
          If the model in question has the TV Guide option, the TV Guide
          option must be turned off before proceeding.
          • Using the customer’s remote control enter “service mode” by pressing the
          following key sequence:
          1. Press the “display” button then release the “display” button.
          2. Wait between 3 and 7 seconds
          3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
          • Panel will now turn on in “service mode”.
          4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
          Until the display shows the “initialize” page.
          5. Press and hold the “display” button until the error indicator (red LED) on
          either the panel or the media receiver goes out.
          6. Exit service mode by pressing the “power” button on the remote.
          If a circuit failure will not permit the unit to remain powered-on long
          enough to complete the above procedure, clear the Trap Switch as follows:
          (You will not be able to see the menus.)
          1. Turn off Main Power Switch on Panel or unplug panel.
          • Depending on which model you are working on, place switch on Digital
          Assembly from "Normal" to "Off" or use a clip to short the high
          voltage. Shorting connections located on upper right corner of
          digital video board. (preventing high voltages from activating)
          2. Place Main Power back on.
          • Confirm both Media Receiver and Panel are in standby mode (unit that is
          trapped will still have both red and green LEDs lit)
          3. Press the “display” button then release the “display” button.
          • Wait between 3 and 7 seconds
          4. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
          • Listen to panel carefully. There will be a very slight relay click.
          Panel will now turn on in “service mode” with only the low
          voltage supplies operating. (no picture)
          5. Press “muting” button 3, 4, or 5 times depending on the model you are
          working on.
          6. Press and hold the “display” button until the error indicator (red LED) on
          7. Turn soft power off, then main power off or unplug unit.
          • Wait 20 seconds
          8. Return switch on Digital Assembly to Normal position or remove shorting clip.
          9. Power back on and troubleshoot normally.
          TRAP SWITCH RESET FOR G-3
          Press and release “menu,enter,power” in sequence or “enter,display,power”
          Exit service mode by turning off power.
          • brainiac88
            • Jun 2014
            • 21
            I carefully followed the procedure, and nothing happened. The TV did not turn on as stated in step 3 (after pressing “<”, “^”, “<”, “>”, and “power” buttons in sequence.)
            Any other ideas?
            • mmartell
              • Oct 2013
              • 3189
              There is a knack to getting the timing down. Hard enough with a functional display never mind without it. I can be a little more concise by telling you what worked for me.
              Press and hold the Display button for about a second then release it. When you release it begin to count "one-thousand ONE one-thousand TWO"... begin pressing the remainder of the sequence at FIVE once per second so that the Power button is pushed at NINE. Good luck.
              • brainiac88
                • Jun 2014
                • 21
                I tried very patiently, multiple times, following the one-second cadence, without success. Where is the IR sensor on the TV anyway?
                But I'm afraid the power supply I replaced isn't the damaged component. I don't know what to do next...
                • brainiac88
                  • Jun 2014
                  • 21
                  PROGRESS!!!
                  Okay so this is what I did:
                  0. With new AA batteries, point the remote at the lower right corner of the TV
                  1. Press the “display” button for 1 second, then release the “display” button
                  2. Wait between 7 and 9 seconds
                  I head a click-click, then a faint buzz sound increasing in amplitude but still no picture or any illumination on screen.... then click. No more buzzing. Both front LEDs still solid.
                  I power-cycled the TV, then tried the sequence again. Same results.
                  Next, I will try the second part of the procedure mentioned above "If a circuit failure will not permit the unit to remain powered-on..." but that requires opening up the TV again... That's for another day.
                  • brainiac88
                    • Jun 2014
                    • 21
                    More progress:
                    I read the Service Manual on Scribd and it mentioned the switch on the board beside the power supply. So I switched it to the UP position, and performed the procedure above, several times, changing the switch position, power-cycling in between, and trying 3,4, and 5 presses of the Muting button. After 20 minutes of trying, I finally cleared the trap indicator - only the red LED was lit. Yes, I taped down the trap switch.
                    So turning on the TV results in it shutting off after 5-10 seconds, and getting a twice-flashing red LED, which means a "power" fault, according to the Service Manual. I tried both power supply boards I have, and same result.
                    I guess now it's time to get another power supply board...
                    • brainiac88
                      • Jun 2014
                      • 21
                      Replacement power board installed, but a used item from eBay. This one is also defective - twice flashing red LED.
                      • brainiac88
                        • Jun 2014
                        • 21
                        More info: If I flip the switch beside the Power Supply board, the TV powers up and does not shut off. But when the switch is off, that means some circuits are not activated.
                        But when the switch is in the normal position, TV shuts off after turning on, then I get the twice flashing front red LED, and the red LED on the power supply board is lit.
                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 05:30 AM
                        • Nopy
                          Sony KDL-55EX500 solid green screen
                          by Nopy
                          I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
                          My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green...
                          03-08-2022, 07:48 PM
                        • Natob82
                          Micro Momentary Push Switch?
                          by Natob82
                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                          12-21-2022, 05:22 AM
                        • grimacelord
                          NEC TurboExpress On/Off Power Switch Replacement Help
                          by grimacelord
                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                          11-09-2023, 09:49 AM
                        • SluggerB
                          Help making a switch work the opposite way with a relay
                          by SluggerB
                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                          02-07-2025, 07:57 PM
